Previous in Forum: cfm   Next in Forum: looking for infrared camera
hp calculation for eccentric lift
09/09/2008 8:02 AM
Hello all,
Can anyone please send me the procedure for calculating the motor hp for the below stated application plz
Arrangement consists of 4 eccentric rollers representing a rectangle 2 rollers connectet to shaft at both ends.
To the center of shafts i.e. parallel to the axis of shafts is the drive shaft connecting thru timing pulley n belts.
arrangement has to lift a load of 2500kg n to a height of about 80 mm
so plz give me solution how to go about it
Re: hp calculation for eccentric lift
09/10/2008 12:20 AM
I can't quite picture what you mean in my mind -
Can you attach a drawing/sketch of this system?
09/10/2008 12:49 AM
i have a pdf file i dnt know how to attach pls let me know
09/10/2008 2:22 AM
Good Answers: 25
09/10/2008 8:08 AM
For Hoist/Crane motor H.P calculation I have following formula:-
Min.KW=KMV/6.12E.
K= Service factor.(for application not more than 16 to 25 cycles per hour K=1 for more than this K=1.2).
M= Weight in Tonnes to be lifted.
V= Specified Hoisting speed in mtrs./min.
E= (0.96) raised to m X (0.99) raised to n
m= No. of pairs of gears.
n= No. of sheaves between drum and equaliser pulley.
Hope this will serve your purpose.
Register to Reply 4 comments
Anonymous Poster (1); suresh sharma (1); yashwanths@webbindia.com (2)
You might be interested in: Core Shafts and Mandrels, Conveyor Rollers, Lift Tables
