Previous in Forum: transformer cooling in desert area   Next in Forum: Design of overhead cable bridge
mylar busducts
09/10/2008 6:55 AM
are mylar busducts being used in high rise hotels at ambient temp of 30 deg C
Good Answers: 230
Re: mylar busducts
09/10/2008 7:49 AM
Hello recivil
Mylar Biaxially-oriented polyethylene terephthalate (boPET) polyester film has several different versions, with differing melting points, electrical properties, and other major physical differences.
I do not know whether the high-rise hotels in hotter climates are using this material in busducts.
Read more here: http://en.wikipedia.org/wiki/Mylar
Kind Regards....
Re: mylar busducts
09/11/2008 4:50 AM
The problem is not in high rise towers or horizontal installations but;-
1- Mylar is a polyester film which accumulate heat inside the bars, so manufacturers using Mylar have to compensate that issue by using more bars cross section, i.e. more weight & cost.
2- Mylar is very sensitve to humidity, so give a reading ( SC ) during insualtion tests
3- Impact strength of Mylar is less than epoxy 3.5 times less
4- Using Mylar insulation create a weak point @ joints
5- Mylar can not withstand a high short circuit current compared with epoxy insulation ( sometimes 50% less )
6- Mylar get scratched after sometimes due to unbalance loads on the 3P where each bar extended depend on load %, so Mylar became stucked & smatched between bars then give short circuit and therefore Mylar products have short life time
On the other hand, epoxy insulation is a part from the bar & extend with the same % with complete elasticity & smoothly
7- All experts recomend epoxy insulation specially for Gulf environment where ambient exceed 50 Deg C. + high humidity.
8- Last, Mylar assembly is a very simple process & cheap and any workshop can assemble it but epoxy is a unique process & only professional lab can do it.
9- Famous manufacturers for epoxy insulation are;
General Electric ( Spectra ) - USA
Siemens ( Sentron ) - USA
Cuttler Hammer ( POW-R Way III ) - USA
LS - Korea
Regards
Eng. Medhat Rizk
medhatrizk2004@yahoo.com
Re: mylar busducts
09/13/2008 3:27 AM
Ducts of Mylar I have not seen.But as explained clearly in the psts it is also not used as support insulator in Bus ducts.
Register to Reply 3 comments
Medhat Rizk (1); nesubra (1); Sparkstation (1)
You might be interested in: Used and Refurbished Equipment, Punches, Conveyor Belts
