A question from a real example:-
A fan motor capacitor fails due to it not being clamped properly and the vibrations abrading the case through. The capacitor data cannot be read. The manufacturer cannot be reached (factory on holiday for all of august) How would the replacement capacitor value be selected?
1/ Obviously we can guess at the capacity from the physical size of the damaged unit.
This may have been replaced in the past which may be why the clamp did not work, so that is not a good method.
2/ We could try different values until we got a sensible current draw and reliable starting.
3/ We could try to match the rating plate figures for current but we don't really know that the load is the rated load of the motor.
Has anyone got a calculation method to select the replacement cap or are ther specific criterion to look for that will help?
We can read RPM, Volts, Amps, phase shift between V-V, V-A or A-A and capacitance.
