Previous in Forum: Manualising a BTR 4 speed auto   Next in Forum: 1995 Corsica Radio on Power Drain?
18 comments
What is This Engine?
09/15/2008 4:21 AM
Good day
Do anyone have any idea - NO Identification plates
1. Who manufacture this engine?
2. What country it is currently manufactured in ?
3. Type of engine ? - Hino or Iveco or any other that is manufactured by a 2nd licensed holder company of older technology.
4. Possible year of manufacturing runs ? (e.g. 1980-1988)
5. From the pic - estimated litre size ? ( e.g. 8.3 Litre)
We have this engine partly as seen - it must be built up to be running.
It actually starts and sounds ok - only the turbo have a slight problem.
From the looks and size it looks like a 7.6-8.3 Litre (Turbo & Aftercooled with a SEN injector pump)
If I look at the ASHOK LEYLAND site from India it looks like it originated there but they
responded negatively.
Thank You
Good Answers: 230
Re: Anyone that knows in this world - Type of Engine ?
09/15/2008 4:43 AM
Hello BLC
If you are able to advise the following, it may assist in identification:
From where did the engine arrive for you to see it? = The source.
What identifying names are on other parts:
  1. Starter Motor - Make and part Number
  2. Starter Relay/solenoid - Make and part Number
  3. Alternator - Make and part Number
  4. Injection Pump - Make and part Number
  5. Turbo - Make and part Number
  6. Oil Filter Element - Make and part Number
  7. Air Filter Element - Make and part Number
  8. Glow Plugs - Make and part Number
  9. Other sub-parts - Make and part Number
  10. If you have taken off the head, advise bore diameter and swept volume, along with the Compression Ratio.
  11. Any other useful facts which may aid identification.
  12. A few more photos may assist, too.
Advise please
If it is yourselves rebuilding the motor, and all identifying marks have previously been removed, it is probable the motor has been stolen at some time, perhaps even in another country, shipped out to your country, sold to another, and you have ended up with it.
Kind Regards....
09/15/2008 5:00 AM
No markings - ANYWHERE !
Good Answers: 230
09/15/2008 5:45 AM
Hello again BLC
Almost certainly a stolen unit, because there is no proper other reason for all markings to have been removed.
Please read what information was asked for, in my earlier reply.
At the very least, advise the following, which may enable a start on Engine identification.
  1. Remove the air filter, and oil filter, look at the Cartridge Make and Part Number, which should be printed on the outside - Advise please.
  2. Dismantle the Alternator, look at the Diodes on the Diode plates - advise small markings (Type Number etc) on the side of the diodes - Advise please.
  3. The same with other parts, look for part numbers - Advise please.
  4. Pull off the head, measure bore diameter and swept volume - Advise please.
  5. Tip the head upside down, place on a level surface, establish how much water volume is required to fill the head depression - Advise please.
  6. Using (4) and (5) above, you can then calculate the Compression Ratio - Advise please.
  7. The Head gasket should have markings on it, advise what those are.
  8. To know what engine this is, you may need to remove the sump, undo a big-end journal, and measure the journal diameter - advise please.
Unless you are prepared to truck this motor around all the Engine Reconditioners you know, you are going to have to do the above, getting dirty hands in the process.
If I was on-site, I could do the above, and have the engine Make, model etc within a day, but as you may appreciate, I cannot physically dismantle parts via remote control.
Reply here - Advise please with and hopefully a proper answer may be given.
Kind Regards....
09/15/2008 11:07 PM
Sparky, one thing you didn't figure into this problem:
In the 80's there were embargos reguarding shipping certain things into RSA, so a lot of equipment was 'sanitized' before shipment, and even now, they won't say squat about an item if it will come back to haunt them.
I've done work for some arms dealers who have neat stories to tell of seeing pallets of God-only-knows-what beeing prepped for shipment to RSA.
Allen
Good Answers: 230
09/16/2008 3:05 AM
Hello Locksmith Al
Thanks for the advice re "equipment sanitisation" before export to RSA, which was a possibility I had not thought about.
Perhaps that is the cause in this case.
Kind Regards....
09/16/2008 4:54 AM
If I was on-site, I could do the above, and have the engine Make, model etc within a day - of course you could !!!!!!
Talk about blowing your own trumpet.
Good Answers: 230
09/16/2008 6:45 AM
Hello "Guest" who is frightened to Post under their Member's name.
It's not trumpet blowing, just the facts.
Kind Regards....
09/16/2008 12:39 PM
....as usual, a (-n unwanted) jest (guest or troll) chiming in who has not the guts to join and give himself a name and some character.....
Who will probably try (completely unsuccessfully in) slagging me off (water off a ducks back as far as I am concerned) because I hit him right between the eyes......
I should stop doing it as it is just too easy.
Its as easy as potting ducks that walk right up to you and beg to be shot!!!
09/16/2008 1:54 PM
I like punctuation!!!!!
LOL
Good Answers: 68
09/16/2008 9:47 PM
Hello Andy Germany:
I agree with you totally. I just wonder why some people who perhaps would not know a 'big-end' if they saw one, insist on throwing insults around?
Can't fathom it myself If they joined or signed in properly and hung around they might learn something which just may help them or others they know in the future.
stay safe
babybear
09/17/2008 11:40 AM
Really well put and thanks.
Good Answers: 68
09/17/2008 12:33 PM
Hello Andy Germany:
Thanks. I had to say something about this as, it was 'someone with no name' who tried to screw one of the few threads I started. They ended up being so rude, not just me but anyone who 'apparently' believed and understood what I was talking about!
stay safe
babybear
Re: What is This Engine?
09/15/2008 11:23 PM
The engine looks like and early Cummings. The cylinder heads are split two cylinders each. Correct? The injection pump mount is a bit strange and I do not recall seeing that set up before.
The only other design of this type I have seen is Perkins. Around 1960.
09/16/2008 5:14 AM
Cummins ruled it out as Cummins. They have a tappet cover / cylinder or full length - looks like a OLD Leyland
Only marking I got is this on the pipe. And the 6.6 kW punched marking on the starter
Yeah - can strip it - will you supply the gasket sets again.
Good Answers: 230
09/16/2008 6:43 AM
Hello BLC
Perhaps Bedford of UK.
Ask your engine source, follow the trail back, perhaps.
Without actual part numbers it's difficult to pin down.
Who painted up the engine, because it looks very clean and 'newish".
Kind Regards....
09/16/2008 8:02 PM
Some years ago Allis Chalmers and Cummings diesel got together and built diesel generators. Looking again at your pictures again, I see a circle with the letter "c" inside the circle. I do remember seeing this on older Allis Chalmer tractors although the engine was gas powered. If I am not mistaken, the injection pump is designed after the caterpillar pumps at that time of build. I am still sitting on 1960 +- a few years. Where the fuel injection pump is connected to the engine, would otherwise be a small hydraulic pump for implement power to the 3 point hitch. Circle C would be a trade mark Id.
Good Answers: 15
09/16/2008 7:14 AM
I have seen similar injector pump attachment in Volvo heavy trucks, used here in the states in the early '90s. Not sure who made the engines in those trucks though.
You might check with Scania or other european mfg.
If you don't have time to do it right the first time, when are you going to have time to do it over?
09/16/2008 2:51 PM
Looks like an old reproduction of an Alis-chombers unit. I apologise for the spelling.
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Register to Reply 18 comments
5star (2); Andy Germany (2); Anonymous Poster (1); babybear (2); BLC (2); charlie_r (1); GroovyCBR (1); Locksmith Al (1); NiCrMoNoMore (1); Sparkstation (5)
