Previous in Forum: Thread cleaning   Next in Forum: Smelly Flue...What to DO?
11 comments
Sanding belts
09/17/2008 1:58 PM
I have sanding belts that have never been used, but they come apart the first time I use them. I contacted several belt manufacturers and they all told me the same thing; "the adhesive breaks down over time (around two years) and will fail when used". I asked if there was a tape I could get to re-splice the belts. They replied that the tape they use is proprietary and I was out of luck. All I can do is buy new belts and not keep them too long. I've tried different adhesive tapes and none have worked. I tried filament tape, garment tape, iron-on-tape. They all failed. So now I present this question to you.
Mr.Ron from South Ms.
Good Answers: 40
Re: Sanding belts
09/17/2008 3:47 PM
More then one site has said to use PVA glue , or cyanoacrylate glue (super-glue)
An additional problem is that the cloth and resin may be drying out and making the paper stiffer. This would put more stress on the joint. I would pull the paper over a steel rod a few times to loosen it up before gluing.
Re: Sanding belts
09/18/2008 8:13 AM
I'll second the super glue. If it fails too, at least you'll have a lot of hand-sanding paper available...sounds like a plot to sell you more sanding belts, to me.
Re: Sanding belts
09/20/2008 4:58 PM
Sanding belts are spliced with tape across a skewed joint. If I use CA, what would I use for a backing? I tried filament tape and Gorilla tape, but they failed.
Good Answers: 40
Re: Sanding belts
09/22/2008 10:43 AM
You need something that can handle the heat such as poly-adhesive tape
Re: Sanding belts
09/22/2008 11:10 AM
The joint failed at the glue line. Backing was still intact. Overnight, the tape just crept until the joint came apart. In actual use, the belt held together.
Re: Sanding belts
09/22/2008 1:44 PM
I used a brand new roll of Gorilla tape. I clamped the finished splice between two blocks of wood and let it set for about 20 hours. After putting the belt back on the machine, the splice started to creep after about 10 minutes and overnight, finally failed completely.
Re: Sanding belts
09/17/2008 11:04 PM
You are not alone...I have a makeshift plow that I use to grind welds in the flat...80, 120, 220 grit etc. I have three knack boxes full of belts that explode on contact. The vendors told me that humidity and time has rendered the belts useless. They to come apart at the splice only. Sorry I cannot be of help, but wanted you to know you are not alone. Needless to say, I have an endless supply of 1" to 1 1/2" sand paper of every grit. Incredible hey? Most of mine are Norton or 3M
Re: Sanding belts
09/18/2008 11:15 AM
The 1" x 42" belts are the ones I use. I looked at them at my local big blue box store and they didn't look like they would stay in one continuous loop for long.
Re: Sanding belts
09/18/2008 12:48 PM
I have not had that problem either at home where I may keep a belt many years before using it, or at our plants in southern CA. This leads me to suspect that the humidity in your area is the culprit. Try storing them in a sealed container with a desiccant.
Re: Sanding belts
09/18/2008 6:13 PM
You may be right about the humidity. My dehumidifier runs continuously and never shuts off.
Re: Sanding belts
09/18/2008 9:36 PM
i use to make my own because i had made a off size sanding machine use contact cement
nick
q.c.
Register to Reply 11 comments
Anonymous Poster (1); dkwarner (1); EnviroMan (1); ronseto (5); rurudr (1); techno (2)
