Hi gang...my gas central heating boiler smells a bit, it does have a bit of up draught (checked with a smoking match). It's worse when there is no wind.
The geometry of the house is such that even with windows open front and back it doesn't help.
The front of the house tends to have a positive pressure relative to the back, resulting in a through draft which doesn't help the flue up draught.
I'm looking at various passive cowls for to slap on the chimney. Electric fans are expensive, consume power and may be noisy.
The flue is a stainless steel 5" diameter running up inside a brick chimney.
The 12" between the top of the gas boiler and the underside of the chimney is un insulated, the rest has some glass fibre insulation between liner and chimney).
I'm considering a H shaped cowl (the flue enters the centre of the horizontal bar of the H) or maybe one of those rotary ones.....But will either help if there is no wind?
Have I missed anything out ? (shoe size 8 1/2)
Any thoughts, ideas, experience?
The other morning Mrs Cat came down and said 'smelly' about 5 times in the first minute...this could be a war of attrition to get me to fix it
Just as well I enjoy the DIY, and arseing about on the roof
