Previous in Forum: How to Spend My Vacation   Next in Forum: Level Measurement and Control Principles
Flow Sensor Transmission
09/18/2008 4:11 AM
hi guys am an instrumentation technician in a cement plant now, i have installed a flow sensor for cooling motor bearings where the sensor and the controller are 25 meters apart now after comissoning the controller has a wire break alarm n yet all the transmisson wires are healthy.the supply to the controller is 90-240 a.c and i have supplied it with a 110 a.c supply.then i had taken the controller n sensor to the workshop n connected it and it was okay where it worked as expected with a 240 a.c supply with no additional transmisson wire apart from sensor to controller. now what should i do?
Good Answers: 230
Re: flow sensor transmisson
09/18/2008 4:36 AM
Hello kinyanjui
In your situation you have checked:
  1. The Power Supply to the unit.
  2. You have checked the wiring for continuity.
  3. You have connected the sensor correctly.
The Controller is saying "Wire Break Alarm ".
Reboot = Reset the Controller, by leaving all connected and disconnecting the electric supply to the controller, at the switchboard or power outlet.
Wait 3 - 5 minutes. (This allows capacitors to discharge in the Controller, and the Controller should go to the Default Position = reboot/re-set.
Switch Power back on after that 3 - 5 minutes.
If you still have a problem after the re-boot/re-set, there are now only 3 possibilities:
  1. Sensor is faulty = Open circuit = Replace Sensor
  2. Controller is faulty = Replace Controller
  3. Sensor and Controller are faulty = Replace both Sensor and Controller
  4. With any of the above, if the equipment was new, contact the suppliers.
Advise your progress please
Kind Regards....
09/27/2008 11:27 PM
Thanks sparks i changed the controller first with a simillar one n got the expected resullts as for feridun comment i had checked the status of the transmisson wires n had an expected ohmic value of about approx.0.01 now its workin i dint expect the controlller to be faulty as its new.cheers man! u guys are great.
Good Answers: 230
09/28/2008 8:00 PM
Hello again, kinyanjui
Your feedback is appreciated.
Kind Regards....
Re: Flow Sensor Transmission
09/18/2008 8:24 PM
1-Either the loop resistance of tranmission wires is too high for the controller to bias the sensor, or
2-The controller cannot produce enough bias voltage when supplied with 110VAC.
Please redo the workshop test at 240VAC, with transmission wires this time, and feedback as Sparkstation said.
Register to Reply 4 comments
feridun (1); kinyanjui (1); Sparkstation (2)
