Previous in Forum: susstion about pipe line   Next in Forum: FK Pump/Vane compressor
replacement of pneumatic diaphram pump by electrical pump
09/19/2008 7:10 AM
I want to replace one pneumatic diaphram pump by electrical pump.
Air requirement for pneumatic pump is at 7.0 Kg/Sq. Cm . Air supply line is of 4 mm diameter.
What will be the size (rated KW) of pump if head is 3 meters .
Flow is 200 Litres /15 minutes.
What is expected KWh saving
Good Answers: 73
Re: replacement of pneumatic diaphragm pump by electrical pump
09/19/2008 8:41 AM
Most of the time, a diaphragm pump is not installed unless there is a reason. And the reason is usually dependent upon what you are pumping. So, switching to an electric pump may not be such a wise idea. Can you disclose what you are pumping?
Are you (or have you) considering a reciprocating electric motor to replace the air pressure function?
Good Answers: 266
Re: replacement of pneumatic diaphram pump by electrical pump
09/19/2008 10:59 AM
Most pneumatic pumps are used to pump flammable liquids if this is what you are pumping I would not recommend changing to an electric.
01/23/2024 9:35 AM
Not without some idea of what the <...pneumatic diaphram pump...> is doing!
  • Wetting agent?
  • Temperature range?
Register to Reply 3 comments
NotUrOrdinaryJoe (1); ozzb (1); PWSlack (1)
