Previous in Forum: replacement of pneumatic diaphram pump by electrical pump   Next in Forum: shaft
FK Pump/Vane compressor
09/19/2008 9:25 AM
We are using FK pump and vane compressor in our operation. What causes for the material to backflow?
Pathfinder Tags: FK pump
Re: FK Pump/Vane compressor
09/20/2008 1:12 PM
Not having a check valve in the discharge line.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
09/22/2008 2:30 AM
Have you a check valve on discharge line?
Look over to the next challenge
09/26/2008 4:37 AM
The check valve on the discharge line is ok. We are producing cement. After a bagfilter the cement goes to an airslide and then to fk pump hopper and then to Silo. We do not experience overload at FK pump its just that the cement comes out from the airslide and the flapper valve at the bagfilter starts to get blocked. Its like air is pushing the cement back at the airslide. Airslide is clear and no build up at the air compartment.
Register to Reply 3 comments
Anonymous Poster (1); KobeKobe (1); user-deleted-1104 (1)
You might be interested in: Compressor Repair Services, Hydraulic Pumps
