Previous in Forum: FK Pump/Vane compressor   Next in Forum: create a wind generator
shaft
09/19/2008 4:06 PM
please tell me which material is suitable for centrifugal pump shaft if material which we are pumping is corrosive.
is it possible to weld broken shaft?
thoughts becomes things.
Re: shaft
09/19/2008 4:15 PM
corrosive is a loose term..........316L SS as a guess.
No do not weld it, it can tear your pump apart.
Re: shaft
09/20/2008 8:28 AM
Or something preciptation hardened, like a 17-4-ph, but it depends on what the corrosive material is.
Re: shaft
09/22/2008 1:09 PM
what is this preciptation hardened- 17-4ph
we are pumping soap slurry
Re: shaft
09/22/2008 2:09 PM
17-4ph is a precipitation hardening martensitic stainless steel, please see links below:
http://en.wikipedia.org/wiki/Precipitation_strengthening
http://www.sandmeyersteel.com/images/17-4PH-Spec-Sheet.pdf
What is the ph and temperature of your soap slurry?
Re: shaft
09/27/2008 1:46 PM
its a pumpetravini make multistage pump.
most of the problem in brine, caustic and lye.
which is corrosive and having ph 10-14.
please advice me.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: shaft
09/22/2008 2:27 AM
Please, specify the pump service ( pressure, temperature, fluid, etc. ) or copy a technical data sheet of the pump.
Look over to the next challenge
Good Answers: 183
Re: shaft
10/04/2008 2:42 PM
Not recommende to weld shafts especially under corrosive conditions the weld could suffer and be destroyed very quickly
Register to Reply 7 comments
Anonymous Poster (1); nick name (1); phoenix911 (1); sandeep lokhande (2); Steve S. (1); user-deleted-1104 (1)
