Previous in Forum: Intel Quad - Core Microprocessor   Next in Forum: Grounding screw assembly rules, succession of parts
How to Tune a Dish Antenna
10/03/2006 3:36 AM
Hi.
I would like to know how to tune the offset dish antenna to receive the signal from the satellite using a simple compas,marking the north, south & east,west.marcking the azimuth angle on the ground.how to calculate simple way to find out the azimuth & elevation angle.
Thanking you.
Pathfinder Tags: antenna satellite signal
Re: How to Tune a Dish Antenna
10/03/2006 10:49 AM
This is easiest accomplished using a satellite locater, available at even Radio Shack, for approximately 30 bucks. This device uses a homing signal and will cause a bar and obnoxious sound on your receiver to inform you of the intensity of your signal that you seek.
It is discriminatory in that it will only select communication satellites. However, there are computer programs that have specific satellites, such as for 2 way communications that are also available. Once you do your explorations, do your mapping. Pay close attention during your initial explorations, pay close attention to the local that you are in if you are travelling, and make a schedule of the signal. You can then make your chart for reference using the map and compass.
I used to set up systems. Mint Condition
Good Answers: 75
10/04/2006 3:18 AM
If you are using a compass don't forget to take into account the magnet variation. The magnetic poles are a considerable distance from the geographic poles. Geo-stationary satellites are above the equator which is referenced to the geographic poles not the magnetic poles. A good map will have the magnetic variation on it usually in both graphical and numeric terms, it will say something like
Magnetic Variation 7º 32.25' E
Which means a compass will point 7 degrees and 32.25 minutes east of the geographic north pole. On World Aeronautical Charts WACs you will see purple lines in half degree increments that join lines of equal deviation in a similar way to the way isobaric lines represent atmospheric pressure on a weather chart.
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Re: How to Tune a Dish Antenna *
10/04/2006 9:22 AM
Masu,
You are referring to magnetic declination. You are substantially correct, except that declination will vary depending on where on the earth you are located. Here in the USA Midwest at this time the declination at this time is nearly zero, but it changes a little every year. Around 40 years ago the declination here was about 5º. There is a website that has a declination calculator. It requires you to know your lattitude and longitude, unless you are in the USA, then you can put in your postal ZIP code. It also has a link to the Getty Thesauras of Geographic Names to help others. The result for my ZIP code, 63304, is like this:
Declination = 0° 9' W changing by 0° 6' W/year
According to the Thesauras and the Calculator, Sydney, Australia is:
Declination = 12° 37' E changing by 0° 0' E/year
Interestingly, you can go back (or forward) in time and see what the declination was for any day between 1900 and 2010.
So, Masu either lives far from Sydney, or he is looking at old published data from years ago.
"What, me worry?" Alfred E. Neuman
Good Answers: 75
10/04/2006 3:07 PM
We are pretty much talking about the same thing except the deviation has any local variations caused by things like deposits of iron included while the declination is just the difference caused by the location of the poles. The figure I gave was just a number I pulled out of the air and figure you gave for Sydney sounds right to me.
Safety - ESD - RF Manufacturing ESD Installer
10/04/2006 7:03 AM
Give this site a try. It helped me. http://www.satsig.net/ssazelm.htm
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
Anonymous Poster (1); jowens (1); masu (2); STL Engineer (1)
You might be interested in: Horn Antennas, Antennas, Chip Antennas
