Good morning, braintrust. I am trying to design a decorative windmill utilizing the top ~20' of an old 1940's steel windmill typically formally seen in the Old West, supported by 4 each ~6" square x 20' timbers; the base of which are set on a 6'-8" square. Since the diameter of the steel propeller is 8', the total height will be close to 47'-3".
I'm thinking of mounting the 6" timber columns on 1/2" x 10" square steel plates, which would be welded to 2" IPS steel pipe, set in large concrete piers, or foundation. What is the best scheme to firmly fix the timbers to the steel plates, but still allow for leveling, or plumbing?
I plan to brace the whole structure with several layers of 2 x 8 horizontal and cross members on all 4 sides, so it will be very rigid. Thx.
