Previous in Forum: HIC TESTED MATERIALS   Next in Forum: Energy Efficiency of Electric Injection Molding Machines
Diamond markings on metal jacketing
09/23/2008 12:28 AM
Dear All ,
The diamond markings tat we provide on the surface of the metal jacketing for the insulated ducts (Hot Insulation ) should be from inside or outside ? wt is the the significant use of this diamond markings techincally ?
Regards
Earnest.
Good Answers: 230
Re: Diamond markings on metal jacketing
09/23/2008 2:02 AM
Hello earnestpaul
Please supply a picture of the "Diamond Markings".
It is possible that the "Diamond Markings" you are talking about are placed there by the sheet metal fabricators, to stiffen the sheet metal, and prevent annoying vibrations from being transmitted along the ducting.
Without a picture, it is not possible to know which "diamond Markings" you are meaning.
To place a picture into a post, please refer: http://cr4.globalspec.com/thread/15743/How-to-insert-Graphics-into-your-Post-to-make-it-more-readable-or-interesting
Reply here, with
Kind Regards....
09/24/2008 9:48 AM
It is indeed for stiffening/dampening.
Bill H.
09/24/2008 10:26 AM
are you meaning diamond coating film?
09/24/2008 5:38 PM
This is for stiffening and sound damping normaly the stamping is from the inside I am not sure if it would make any difference to performance but I have never seen it the other way.
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
09/24/2008 9:03 PM
Never seen any done from the outside. I would suggest it is from the inside because of a production method of machine setup.
Bill H. (1); cnpower (1); coconutpete (1); dadw5boys (1); Sparkstation (1)
