Previous in Forum: Solar panel   Next in Forum: DIY Lead Acid Batteries for Home Standby Power
X/Y Mylar grid paper sheet
09/23/2008 6:42 AM
Looking for mylar grid (x/y type) paper (type of polyester film) of 900mm X 600 mm and thickness of 150-200 micron.
It is required for calibration of laser system on X-Y plane. The laser system will burn the mylar paper in x-y matrix palne of 900mm X 600mm size. The distance between holes will be measuered with optical scanner and comapred with its nominal value. The correction will be fed to x/y scanning system of laser for the correction/calibaration of the laser system.
If anyone is aware of availability of such mylar sheet of paper?
Pleaser send your relpy to lastek@gmail.com
Re: X/Y Mylar grid paper sheet
09/24/2008 12:26 AM
Hello
From USA
Venture Tape Corporation from USA.-Polyester Reinforced Triplex Foil 1577CW.
+44 (0) 1327 876 555.
From Europe
Tarec Insulation -Mylar Triplex foil .-+44(0) 1706 715500 UK .
+32(0) 2 674 83 20- Belgium
Kingspan Industrial Insulation Ltd.-Polyester Reinforced Triplex foil -+44(0)1544 388601.
Rothel(UK) Ltd -Foil Scrim -PE.-+49(0) 234 87940- Germany .
Hope the above information will be useful
Regards
Earnest.
09/24/2008 3:23 AM
Thanks for your response.
Just checked all above your recommonded supplier, unfortunately could not locate required things from their product range.
It will give more clear idea on this issue if you can have look at sample of X/Y mylar grid required for our application. <lastek.info@gmail.com>
09/24/2008 9:11 PM
We use mylar tape on aircraft wiring. our came in 5,000 ft rolls but it was 1/2 to 1 in wide.
Look for a mylar tape manufature like http://www.rplastics.com/mylar.html
Anonymous Poster (1); dadw5boys (1); earnestpaul (1)
