we are using 60 amps three phase variable transformer .input voltage is 415V and output varry from zero to 460volt.We want to know what is the minimum capacity of MCB is required.
If you need Fault Discrimination in your arrangement, use a larger MCCB for the Primary, with a lower Amperage MCCB for the secondary.
Example: Primary: 100 AMP MCCB with Secondary 80 amp MCCB.
If magnetising current (Switch-on surge) trips either of the above MCCB's, then use: 160 Amp MCCB Primary, with 100 Amp MCCB secondary.
The use of a larger MCCB for the Primary, will ensure by (Discrimination against Cascade Fault), that if the secondary loading is too great, the Secondary MCCB will trip, leaving the Primary MCCB not tripped.
Kind Regards....
