Previous in Forum: MCB Minimum Capacity   Next in Forum: Watts to Power an Automobile
Calculating Power Consumption
09/25/2008 9:32 AM
how to calculate the power consumption in kva for a site with 3ph and 1ph loads
the only parameter i had is the per ph amper consumption
Re: Calculating Power Consumption
09/25/2008 10:18 AM
To calculate power consumption
KVA x power factor = kilowatts
KW x hours used x cost per kwh
Add 1 phase and 3 phase together.
Good Answers: 61
09/26/2008 10:09 AM
If you don't have actual voltage, you should at least be able to get nominal voltage of both load types from equipment nameplates. A good estimate of apparent power (KVA) can be obtained using the procedure shown below.
For the 3ph system, calculate the average current for all 3 phases:
(I1 + I2 + I3)/3 = Iaverage
Using average current and nominal voltage, calculate 3ph KVA:
(Vnominal3ph x Iaverage x 1.732)/1000 = KVA3ph
For the 1ph system, use the measured current and nominal voltage to calculate 1ph KVA:
(Vnominal1ph x I1ph)/1000 = KVA1ph
The total apparent power used is the sum of the 3ph and 1ph power flows:
KVAtotal = KVA3ph + KVA1ph
Register to Reply 2 comments
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
