Previous in Forum: Wind Turbine Blades   Next in Forum: Large size lens/mirrors for solar energy focussing
12 comments
Electricity from a Water Pump
09/29/2008 9:41 AM
Greetings. I have been trying for months to get a supplier for a water pump with reversed wiring of the motor to generate 2-5kW of electricity. Searches in google have not yielded results. Is this possible in the first place.
Re: Electricity from a water pump
09/29/2008 11:55 AM
you need a turbine not a pump and a generator not a motor.
10/03/2008 4:45 AM
Greetings. Thanks for the comment. Best regards and God bless you
Re: Electricity from a Water Pump
09/30/2008 9:00 AM
This has been done before, not very effiecent but it will work. It is done in mining operations where they have to pump over a hill or mountain. Once the pump gets the water running over the hill, a siphon is created. The water is then pulled through the pump and it can be used as a generator. That is all I know on it. I think that you need to talk to an electrical engineer to figure out how to get this to work.
10/03/2008 4:47 AM
Greetings. Thanks for the comment. Best regards and God bless you Murage
09/30/2008 10:11 AM
A correctly setup motor will be quite inefficient as a generator. It will work, but only "just". Why not get a proper generator?
10/03/2008 4:48 AM
Greetings. Thanks for the comment. This will be useful for follow-up. Best regards and God bless you. Murage
Good Answers: 53
09/30/2008 12:06 PM
Hello,
You need to fix a pump in between motor and a generator shaft and run it in a manner as suggested by A11an,
If you don't want to use a separate motor and generator then you can have PMDC Motor or a servomotor with an ordinary pump,
10/03/2008 4:49 AM
Good Answers: 128
10/06/2008 12:55 AM
Murage,
I believe that a 3-phase motor will become a generator if you have an outside source of energy spinning its shaft. Many water pumps are not as efficient when running "backwards", and you would have to pay attention to the possibility of a loosened nut where the pump impeller is attached to the shaft.
There are a number of "pumped storage" peak generation reservoirs in use, where the motor is pumping water to an elevated reservoir during non-peak hours and then the water is run back through the same equipment to generate electricity during peak hours.
Perhaps you can try this with a pair of pumps. Connect the power to the first one and plumb its discharge pipe to the discharge pipe of the second one. Attach a load to the "motor" of the second pump and measure the amount of power produced. It will be generating power. Let us know the results.
--JMM
10/06/2008 8:08 AM
You wish!! its not quite as simple as you try to make it, even DC motors are not set up correctly to run as a generator......AC especially not!!!
For small amounts of AC power try using a stepper motor with a permanent magnet rotor, they do the best I know.......but do not forget the speed is also the frequency!!
Good Answers: 128
10/12/2008 1:54 AM
Andy,
I've checked some of my resources. I wish know. Do a Google search on the term "pumped storage".
Regards--JMM
Good Answers: 19
10/17/2008 10:33 AM
I remember posting on this one quite a while ago, but can't find it. if the motor is an induction motor and supplied by three phase (to excite the windings) and the pump is the common impeller type, then it works and is surprisingly very efficient.
but there is not enough information in your question to make appropriate suggestions
flow rate, head, infrastructure, available resources etc.
Register to Reply 12 comments
A11an (1); Andy Germany (2); Anonymous Poster (1); HUX (1); jmueller (2); Murage (4); rakesh_semwal (1)
