Previous in Forum: Evaporative condenser working with propane/butane   Next in Forum: radius dimensions on structural angle stock
welding rods
09/30/2008 10:47 AM
please guide me for use of welding rods in welding process
following elecrodes i am using for different applications. please suggest me for some more options:
1) ss welding - geka EN 1600 AWA5.4 E308L(E104 R 308L)- 2.5 DIA.
2) ss welding - TS 308L-AWS A5.4E308L- 3.2DIA.
3) MS welding- AWS A5.1 E6013- 2.5/3.2 DIA.
4) Low hydrozen - OK 48.00 UNITRODE-7018 E5143B
5) MS TO SS welding - 680 AWSE WELTECH 6013 AND WELTECH F14
Please advice me.
thoughts becomes things.
Re: welding rods
09/30/2008 8:18 PM
Re: welding rods
10/01/2008 8:29 AM
Describe what material you are welding under what conditions for what purpose. Then it would be feasable to form an answer. Telling you what welding rods do is a poor substutute for the direct application of expirience. If you needed to ask the question about the rods you don't have the skills to apply the answer.
Re: welding rods
10/01/2008 9:14 AM
1.304ss to 304 ss e308l OK
2. see 1
3.ms/cs to ms/cs e6013 OK for root
4. ms/cs to ms/cs e7018 OK w/backweld
5.ms/cs to ss e6013 NOT OK use e309/e309l
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
Re: welding rods
04/23/2024 7:39 AM
It appears that a telephone call to the supplier of these <...welding rods...> is well overdue.
Register to Reply 4 comments
Anonymous Poster (2); erssk (1); PWSlack (1)
