Previous in Forum: help me   Next in Forum: Any common anti-thixotropic material?
12 comments
mild Steel and Stainless steel, which one more expensive?
10/04/2008 1:09 AM
hi, can anyone let me know which 'steel' is more expensive? and which one is more suitable for constructing a storage tank for acetic acid (high purity).
Re: mild Steel and Stainless steel, which one more expensive?
10/04/2008 3:28 AM
Mild steel is the cheapest stuff you can get, totally unsuitable for storeing just about any liquid unless lined or plated!
Stainless may be ok...but there ate many grades.
Try Googling 'chemical compibility steels' or similar.
Plastics are commonly used for barrels/tanks too....repeat the search but substituting 'plastics' ..
Good Answers: 74
10/04/2008 12:34 PM
Here is what Celanese recommends.
Bruce
10/04/2008 10:56 PM
So it settles--
Store the stuff in the 200litre HDPE drums-- no messing with SS/MS Welded Tanks.
10/04/2008 11:00 PM
i see, thanks all
10/05/2008 2:09 AM
From NACE handbook "Corrosion Data Survey, Metal Section", sixth-edition, Table at page 2 for storing aerated Nitric Acid:
a. At 100% concentration at temp. 50 oF (19 oC)
- Using carbon steel shall have a corrosion rate about 1.27 mm/year.
- Using stainless steel (304 & 316) shall have a corrosion rate about 0.05 mm/year.
b. At 100% concentration at temp. 100 oF (38 oC) and above:
- Using stainless steel (304 & 316) shall have a corrosion rate about 0.508 mm/year.
10/09/2008 7:13 PM
Sorry, the data derived at my Post #5 is for "aerated Acetic Acid" not "aerated Nitric Acid".
Good Answers: 56
10/05/2008 3:58 PM
I suggest you contact any company that specializes in the design and construction of acid based ore separation tanks.
There is, for example, a large population of holding tanks (100,000 gallons is common)on the Solomon Islands of New Guinea that are used to contain the acid and copper ore slurry that is part of the mining operation.
I'm not a chemist, but my understanding is that the process of leaching ore from crushed rock depends heavily on high concentrations of acid which is then drawn off from the residual rock sediment. Those tanks strongly resemble the large round tanks and rotating rakes common to municipal sewage treatment plants.
I helped design the power units needed to move that mix and as far as I can remember, the tanks were not lined. I don't trust my memory, so don't you either.
L. J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
10/06/2008 4:28 AM
you want 316L
10/06/2008 8:37 AM
It all depends- on how corrosive we are talking. I can't speak to plastics but 316 is the standard then going into duplex grades like 254SMO (much more expensive and lasts a great deal longer). I am a steel guy an "mild steel" is definitley not the answer.
10/07/2008 8:34 AM
Polypropylene would be a better choice.
10/07/2008 7:52 PM
thx your information, can u give me more detail or any reference site?
10/09/2008 4:20 PM
I work in the marine industry and all of the cargo tanks we have for acetic acid are made of 316 Stainless Steel
Register to Reply 12 comments
Abdel Halim Galala (2); alindsay81 (1); Anonymous Poster (1); ba/ael (1); Laughing Jaguar (1); MSsteel1 (1); MUKULMAHANT (1); PWSlack (1); user-deleted-1105 (1); weasley (2)
