Previous in Forum: pc motherboard design   Next in Forum: Distance protection
8 comments
end switch
10/04/2008 8:21 PM
I am connecting a boiler to a Taco 504 switching relay and the wiring diagram calls for a wire from the XX end switch of the 504 to the TT of the boiler.
Can someone explain to me what this connection actually does?
Thanks
Good Answers: 140
Re: end switch
10/04/2008 8:31 PM
Post the drawing.
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: end switch
10/04/2008 11:44 PM
It sounds like it may be the switch, that if not installed properly, will cause a couple of city blocks to be leveled.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
Re: end switch
10/05/2008 11:59 PM
No thats only if the red wire is cut. Connecting the wire will cause implosion, black holes or something.
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: end switch
10/06/2008 5:16 AM
Working with a boiler start circuit, the end switch could be from a combustion air damper or water flow switch that must be proved before the boiler start circuit is completed. A complete system layout showing all devices in your system would help.
ilcllc@comcast.net
www.innovativelogicalcontrols.com
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Re: end switch
10/06/2008 8:52 AM
From the Taco wiring diagram that you apparently have - very first statement after diagrams:
Operation:
When any thermostat calls for heat, the appropriate circulator
is energized and the isolated end switch (X and X) will start the
boiler.
Re: end switch
10/06/2008 11:36 AM
Thanks for your response, I understand it now, and in my case I did not have to use the end switch.
Re: end switch
10/06/2008 9:05 AM
chibcha38; the thermostat & 24 ac volt transformer are wired to operate the zone valve, when valve is opened to allow water to flow the end switch closes to turn on the boiler & circulating pump. the end switch connected to the T T terminals on the boiler or the zone control panel. perry
Re: end switch
10/06/2008 11:35 AM
Register to Reply 8 comments
Anonymous Poster (3); jcchiefeng (1); Kilgore Trout (1); North of 60 (1); perry (1); Phys (1)
