Previous in Forum: oil storage tanks   Next in Forum: experimental results of single cylinder four stroke petrol'
canned pumps
10/06/2008 1:45 AM
We want to take cooling water for our 120 MW hydro machines in an underground power station (high head) from the draft tubes. The approximate requirement of water shall be 250 litres per second and pressure at pump outlet shall be about 6 kg/sq. cm. Are canned pumps for this capacity available? We wish you utilise these cooling water pumps for dewatering also. Any suggestions ?
Re: canned pumps
10/06/2008 11:11 PM
Why use a pump at all? You already have huge amounts of water available under considerable pressure. Use Venturi for dewatering.
Re: canned pumps
10/08/2008 4:46 AM
Exactly. There's up to a further 1/7 of a megawatt to extract from the cooling water stream. Back-pressure turbines, anyone?
Register to Reply 2 comments
