Previous in Forum: Short Answers Only   Next in Forum: Piping Course
Small-Bore Buried Gas Piping
10/06/2008 12:25 PM
What's the latest thinking on buried gas piping? We used to just specify coated, cathodically protected carbon steel piping for gas and other fuels, but this is a 1" line installed for a temporary process. Anyone using HDPE and getting local approval? I am checking with local jurisdiction, but they are sometimes the last to be up-to-speed on new developments.
Thanks for any feedback.
Re: Small-Bore Buried Gas Piping
10/07/2008 12:11 AM
Here in the metro Milwaukee area, WE Energies will make up the HDPE line with the proper fittings crimped on for you for underground use.
It costs a right penny, but you know it's done right then!!
Allen
10/07/2008 7:58 AM
It is fairly common use in Australia , widely used in natural gas reticulation, it is well accepted.
Obviously it is up to as you say local and national regulations.
10/07/2008 8:26 AM
Good morning thinman56. HDPE meeting ASTM 3406 or 3408 has been in use many years in the sw US. I recommend 1" CTS SDR 11 for 60 psig or less, altho you don't mention the pressure or your location. There're several fitting manufacturers to choose from, one being R.W.Lyall Co. in Ca.
10/07/2008 8:50 AM
Thanks, all, for the responses. Local jurisdiction also says HDPE is fine for low-pressure (<100 psig) natural gas and propane, so we'll go with that.
Cheers
10/08/2008 4:36 AM
Check the colour codes, though. In the UK, gas is yellow and potable water is blue. Otherwise they are similar materials.
Good Answers: 12
10/08/2008 9:53 AM
In my jurisdiction, plastic is now the standard...and required. And preferable. Flexible for easier installation, doesn't corrode. However, cannot be continued inside building where black pipe still the way. This is the latest thinking and standard.
Register to Reply 6 comments
CowAnon (1); flyinghigh (1); garth (1); Locksmith Al (1); PWSlack (1); thinman56 (1)
