Previous in Forum: Optimizing Compressed Air Systems   Next in Forum: difference between class and schedule of pipes?
backless of gears
10/07/2008 3:06 AM
anyone can tell me that what is the backless in gear & how we repaire that,please tell me also the clearance between two matching gears.
Good Answers: 58
Re: backless of gears
10/07/2008 5:19 AM
backless? I assume you mean backlash, if you google gears and backlash you will get a fund of information.
The second part of your question is of no use as you do not say what type of gears, size etc. Nobody can give you a sensible answer with this amount of information.
03/17/2013 1:29 AM
Dear Friend,
I think you are referring BACKLASH for the Gear and it is not backless.
Generally the BACKLASH will be 4 to 5 Percent of the MODULE, and ROOT CLEARANCE will be 0.225 x MODULE.
Pl. refer any Standard book on Gear. The GEAR TRERMINOLOGY is to be understood properly, like MODULE, BACKLASH, ROOT CLEARANCE, ADDENDUM, DEDENDUM, DIAMETRAL PITCH, FLANK, TOOTH THICKNESS, ROOT STRESS, APPLICATION FACTOR etc.
DHAYANANDHAN.S
You might be interested in: Metric Gears, Gears
