Previous in Forum: COSMOSworks, SolidWorks 2006, and Windows Vista   Next in Forum: Waste, Scrap and Structural Steel Fabrication
16 comments
Methanol Leaks and Gate Valves with Hastelloy Trim
10/08/2008 3:26 AM
Before this, we used gate valve with Stellite Trim for 2 nos of 12" and 4 nos of 32" Gate Valve with Body Material of A216 WCB for service of Methanol with normal temperature of 95 degC. The problem is when we fully close the gate valves, Methanol still leaking/passing through all valves. Now, we decided to change the gate valves trim to Hastelloy Trim as advised by our Process persons. Can someone provide me any related information like their experiences, technical documents or others about the use of Hastelloy Trim in Gate Valve for Methanol service as a support for us to use the Hastelloy Trim for our Gate Valves to solve the Methanol passing/leaking?
Wan Anuar, Malaysia
Pathfinder Tags: Gate Valve Hastelloy Trim
Re: Can Hastelloy Trim in Gate Valves solve problem of Methanol passing/leaking?
10/08/2008 4:27 AM
Changing the MOC of the valve trim cannot affect its leak rate as much as correcting the alignment and any wear of the components!
Is there a temperature change issue inside the valve that can affect the dimensions and positioning of the components inside it?
Re: Methanol Leaks and Gate Valves with Hastelloy Trim
10/08/2008 1:38 PM
Why do you not install another valve piping and have two while one stays open to a chamber to act like a reserve tank which would deplete when the second valve opens and the first is closed. In this way the leak should stop and the result will be no real change in the Methane flow. One piping is a relief valve service to maintain a lower pressure on the main valve.
So is the leak at the stem or the bolted joint.
Could this be caused by external corrosion or tampering of the turn screw?
If external corrosion maybe the coating is inadequate, newer coatings certified for newer pipes and valves are available, change of a old coating valve and re-coating it with a new coating might be less expensive.
If there is a temperature change issue inside the valve, it then could be a coating issue, the coating is to keep the material of the pipe and valve from altering due to a change in temperature which would be a difference between the external temperature and internal temperature. Manual operators could have caused the coating of the old valve to dislodge and be interference in the shaft else vandalism would be a issue.
This should Stop Methane Passing or Leaking in a Gate Valve.
Serving The Public Better The Electric Vehicle Free Conversion Foundation (EVFCF)
10/08/2008 10:52 PM
I think you need to read the question again!
10/09/2008 8:48 AM
the problem is inherit with the gate valve. the seat of the gate valve, i assume, is also metal. the torque required to seat the valve properly is much higher than a soft seat. since your service is a clean service and not high temperature (, methanol at 95C, could be a two phase?), you resolve the problem by going with a soft seat like PTFE.
hastelloy should not affect the leaking issue.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
10/09/2008 9:17 AM
You don't specify if your valves are hand or otherwise operated (motor...)
Neither the type of gate valve (solid, flexible or split wedge, parallel sided with internal wedge, i.e Anchor Darling type...)
Anyway, stellite is a very common material for gate valves in the wedge to seat contact faces, independent on the body material, which in your case is carbon steel but its also common for stainless steel.
Of course to make a seal between two metal surfaces you need two things: flat faces (no radial scratches on the hard faced zones of seat or wedge) and a minimum stem thrust. If no thrust enough (for example in the case of handwheel operated and high pressure) you can have leaks because you don't have the minimum contact stress to assure tightness.
If motor operated and hard seated (torque switch controlled) then probably you have the seat damaged and need just refurbish it (by lapping may be).
There's no difference relative to the fluid you use because it doesn't attack any body or trim material.
P.D. For a gate valve don't use plastic or any other resilient trim materials.
Kind regards
10/09/2008 10:33 AM
How much leakage? A single gate valve (as compared to a double block and bleed configuration) is NEVER considered suitable for isolation. Some leakage is almost certain with such a low viscosity liquid. Have you examined the seat cavity to see if any debris has accumulated? Often, small particles of ?? will collect in the wedge pocket and prevent the gate from fully closing. Orienting the valve stem down will minimize debris problems. Also, to what leakage spec did you purchase the valves? Standard tolerance valves ARE NOT (leak tight). If you want (need) very low leak shut-off, you will have to go to soft seated butterfly type. Metal -to-metal wedge seating (cast iron, cast steel, Stellite, Hastelloy, chrome) is not suitable for the non-lubricating characteristics of methanol. Scuffing of the seat surfaces is a virtual certainty, and leakage after the first closing almost guaranteed.
Keith E Bowers, PMP
10/09/2008 11:19 AM
You may want to consider using a double seated gate valve with a vented, concave gate. Such a gate valve seals on both sides of the gate, has machined seats that mate with the matching body seats, and has a vented gate cavity that lets the operator know if either seat begins to leak.
In response to a nother response methanol boiling point is 64.7 deg centagrade, so at 95 deg and atmospheric pressure it is a vapor, not a liquid.
10/09/2008 12:21 PM
We used a zero leakage Parallel Disc Pressed Butterfly Valve for a methane application in Canada and all we specified was WC6/Stellite overlay,the gate valve will not perform with what you want,Butterfly Valve.
10/09/2008 12:36 PM
Good solution, changing the valve has a terrific effect. No Stem!
10/09/2008 12:33 PM
I found a answer to the question, it has to be relative to your specific product. Seriously look into it deeply to resolve the situation of the atmosphere surrounding the exterior of the piping.
I realize that the Gate Valve may be of good quality but there are still instances that can cause problems esp. at the stem. With each stroke of the valve stem downwards, molecules of water vapor in the atmosphere are entrapped in the peaks and valleys of the stem's microstructure, and are drawn down into the secondary packing rings. As the stem retracts, a molecule of the permeated fluid may be pulled up into the packing rings. If the molecules of moisture and permeated fluid come into contact, a "solution" may be formed. This "solution" will be highly "concentrated" and can be highly corrosive. If the stem material is vulnerable to the concentrated solution, chemical attack of the valve stem in the mid-range of the packing zone may begin. Once this mechanism begins, the result may lead to premature stem failure.
When dissolved in moisture H20.
hydrogen sulfide + water ---> Hydrosulfuric acid; a weak acid even when concentrated.
H2S + H2O H3O + + HS –
chlorine gas + water --> hydrochloric acid; + oxygen gas a very strong acid even when not concentrated
2Cl2 + 6H2O 4H3O + + 4Cl – + O2
acids are formed in both cases. The hydrosulphuric acid is a weaker acid that 316 SST is sufficiently corrosion resistant against. However, the hydrochloric acid is a strong acid that corrosively attacks 316 SST. Both increased pressure and temperature accelerate the corrosive mechanism. However, the overall rate of corrosion is very low as the permeation rate is very low. Chlorine gas is an example of a fluid where alternate stem construction of Hastelloy C-276 will maximize unit life and proper functioning of the secondary stem seal design. Use of alternate stem material is subjective and dependent on many various factors, and is like most CPI decisions, based on value judgement.
NOTE: The corrosive effects are primarily limited to the stem/secondary packing rings zone where moisture and acid molecules interface.
Chemicals Known To Permeate TFE
* Fluids where alternate stem materials are recommended.
** Corrosion effects on metallic parts unknown.
* Ammonium beryllium fluoride
Benzene
* Bromine
* Bromine (water - 3% saturated)
* Bromine chloride
Butane
Butyl bromide
Butyl chloride
Butyl phenol
Butylene (Butadiene)
Carbon bisulfide
* Carbon tetrachloride
Chlorinated phenol
* Chlorine (5% in CCl4)
* Chlorine dioxide
* Chlorine
* Chlorobenzene
* Chlorobenzyl chloride
Chloroform (Trichloromethane)
* o-Dichlorobenzene
Dichloroethane
Diethyl ether
* Ethyl benzene (acidic)
Ethyl ether
Ethylene chloride
Ethylene dibromide
Ethylene dichloride
* FREON Fluorocarbons
Hexane
* Hydrobromic acid
* Hydrochloric acid
* Hydrofluoric acid
Hydrogen
* Hydrogen chloride
* Hydrogen cyanide
* Hydrogen fluoride gas Hydrogen sulfide
* Iodine (gas)
* Iodine (Tincture of)
Methane
Methyl chloride
** Methyl chloroform
** Methyl chloromethyl ether
Methyl ethyl ketone
Methyl isobutyl ketone
** Methylene bromide
Methylene chloride
Naphtha
Naphthalene
Nitric acid
Nitrobenzene
Nitromethane
Oxygen
Perchloroethylene
Phenol
* Phosgene
Potassium cyanide
Propane
Propylene oxide
Styrene monomer
Sulfur trioxide
Sulfuric acid
Tetrahydrofuran
Toluene
Toluene (25%) + kerosene (75%)
1,1,2-Trichloroethane
Trichloroethylene
** Trimethyl propane
Vinyl chloride monomer (liquid)
** Vinylidene chloride (monomer)
Xylene
10/09/2008 1:01 PM
Charles Jones,Thank you your discussion is extremely informative and very helpful.
Good Answers: 25
10/11/2008 9:51 AM
And what's the corrosive product of reaction between methanol and water? You've included a great list of products but it doesn't includes methanol.
Even in the case a few water molecules get inside a 32" gate valve what will be the concentration of such "corrosive" product? Will then attack a stellite seat?
Very good information but irrelevant to the case.
Kind regards
10/09/2008 12:38 PM
I believe that Keith Bowers has given you some great advice based on my 40 years in Nuclear submarines,Paper Mills and the last 32 in Chemical plants.The following is my belief for Solvent Valves of ALL types based on maintaining fluid systems.This is what worked for us.I know as I was one of the the mechanics.
The seating area of a Gate Valve in any position but handle down,is a great place for trash to collect.Nearly all but the most expensive Gate Valves seep and leak.Some a little,some a lot.Cheap Gate Valves caused more incidents in my 40 years in maintaining systems than all other Valve types put together.Several times causing MAJOR incidents including injuries to people,small and Major fires,small explosions and massive property damage to the plants.I was there! They are cheap to purchase,but very expensive overall beside a good Ball or Globe Valve.They are the most miss-used valve that I have seen in the USA and abroad.
We found ball and Plug valves with Teflon seats to be great all position stop valves.Most are repairable.Certain ones can be quickly repaired in place without removing the valve from the systems as all worn parts come out of the top of the valve for replacement with new parts!These and Gate valves are made for on and off,not for flow control.Any attempt to use them for flow control often will cause erosion as will a leak!Some tapered "Plug Valves" have been made to be able to tighten down or adjust for wear when they start leaking.A thin gasket added on top of the plug or seat to push down has often lasted for many more years.
For flow control or trashy systems,Globe valves with the "right seat" to be great all position valves.
I do not know how clean your system is or any of the system facts.
The correct Gate Valve,installed correctly in the correct place is fine.The shame is that this is very uncommon,even on prints drawn by professionals.Check it out in your plant!It may save you some grief."Incorrect" has certainly caused enough in my life.Alfred
10/09/2008 12:53 PM
The problem with the gate valve in may instances is that it takes up to much real estate,with severe service we have been using this new PDP Butterfly valve that is more reliable,more versatile and smaller in size and weight.It's patented shutoff is new and unique to our valve industry.
03/06/2013 7:07 AM
I very much doubt that the change of material can be the cause of leakage. Other factors may influence: is the valve lapped properly (though gate valves don't tend to have lapping problems)...? Has pressure increased? And temperature?
Working with corrosion-resistant valves for the petrochemical industry.
09/06/2024 4:18 AM
For process isolation for safety, the concept of block-and-bleed should be applied:
  • Two valves in each line are closed, then two pipe spades put in to isolate, one downstream of the upstream valve and one upstream of the downstream valve, and the section of pipe between them is vented though a locked-open valve or a locked-open flange (Labelled padlock passed through one of the bolt holes).
This practice needs to operate as part of a Permit-To-Work procedure to protect the individuals working downstream. The reason is that it is not acceptable to attempt to assure safety through a valve being closed, especially as it is known that valves can leak - as in this particular case.
The concept needs to be designed-in at HazOp stage during the design process, under the keyword "maintenance".
Yes - it's a faff to do. Not nearly as much as attending people's funerals though - assuming enough remains can be found to bury.
Register to Reply 16 comments
Anonymous Poster (3); CharlesJones (3); Import/Export (3); Keith E Bowers (1); khangnguyenca (1); Kwetz (2); pfeinstein (1); PWSlack (2)
