Previous in Forum: Mitsubishi GX Melsoft Software - Version 7   Next in Forum: ORTHOGRAPHIC VIEW OF VESSEL
Installing Virtual Box for Windows XP
10/09/2008 9:31 AM
i have suse linux in my laptop and try to install windowsxp . i don't know about virtual box please hellp me ,how to install winxp in virtualbox
Pathfinder Tags: software
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: Installing Virtual Box for Windows XP
10/09/2008 10:16 AM
Have you got as already installed vbox but failed to launch this service on linux either you couldn't install it at all? Have you met a lack of software components to satisfy all dependences? If so you can install ones from your Installation DVD either visit site pbone.net for RPM downloading.
Visit an innotec site where you can download pdf doc for virtualbox. Read one thoughtfully. You can visist appropriate Suse linux community forums to sort you problem out.
If you succeeded to install vbox you have to create virtual HD (there should be enough disk space for that) for your virtual machine then turn it on with installation XP DVD at you CD-drive, install XP there and enjoy.
Vbox is a very good stuff.
10/09/2008 4:37 PM
Well you need to install VirtualBox first. Have you done this? Go here:
http://www.virtualbox.org/wiki/Linux_Downloads
Make sure you download the appropiate rpm, based upon your opensuse version and computer architecture. Then you need to install it using a command something like:
sudo rpm -Uvh VirtualBox-2.0.2_36488_openSUSE103-1.i586.rpm
Then just wait for the install to finish. To launch it you can do it through the system menu or I believe you can just type VirtualBox into the command line.
VirtualBox is great though. Have fun!
Register to Reply 2 comments
