Whilst looking through a chain catalogue, I found Variable Speed Chain, but have not found a decent illustration of how the system works. Any information would be appreciated.
Tony
The nice thing about Standards is there are so many to choose from.
Then the first two links by first Guest should help you understand.
Put that chain into a gearbox with variable pulleys that open/close due to centrifugal force (just like the animated gif on the "how stuff works" page with substituting the belt for the chain)
It is called PIV drive which provides posative variable speed drive and should be available with your local gear box dealer. Now a days people use VFD drive,variable frequency drive, which is electronic drive and does not need mechanical hardware. These are mfd. by Siemens and others.
Sure this is known as PIV (Positive Infinitely Variable) Gear box.
The principle is that you have a fixed length of chain running between two cone pulleys operating at fixed centres. One of the cone pulley is spring loaded and other can be opened and closed manually to achieve desired ratio of out put. It is like having a stepless combination of drive and driven pulleys. For a given input rpm, you can either reduce the output rpm or increase it to suitable requirement in the given range. A word of caution, remember to change the speed ratios only when the gear box is running as when you manually open or close one set of cones, the other, which is spring loaded one, accomodates itself to a different diameter due to fixed chain length.
I had no time to go through the links provided by other gentlemen. You may find a better explaination there.
