Previous in Forum: Piping Material-valve   Next in Forum: gas scrubbing
pipe type
10/13/2008 5:10 AM
Pipe is of 2" size & 5' long. Sockolet is introduced at 2' .Should the pipe has plain end or bevel end & why? Whether type of pipe ends used depends on conditions such as Pr,Temp, medium,corrosion,insulation,pipe material,pipe class,etc.?
Be simple and specific for a great success in Life
Re: pipe type
10/13/2008 9:01 AM
Of what material is the pipe made?
What's in the pipe, and what is its temperature and pressure?
Re: pipe type
10/15/2008 2:58 AM
Use plain end pipe if using socket weld fittings and use bevel end pipes when using welded fittings.
Register to Reply 2 comments
