Previous in Forum: pipe type   Next in Forum: Stainless Steel Spec Cross-Referencing
gas scrubbing
10/13/2008 11:05 AM
How to calculate the volume (M3) Blower capacity,
Gas - HCL
Open Tank size 1.5 m x 1.2 m x1.5 H
Calculate . Velocity, Volume, Pressure of Blower
Can you give me the formula and calculation
User-tagged by 1 user
Re: gas scrubbing
10/13/2008 5:01 PM
impossible, not enough information. Need someting with the units of time. and what you want to do, like empty the vessel of 10,000 kg in 30 minutes?
Re: gas scrubbing
10/14/2008 2:16 PM
Dear Vicini,
Iam having a Pickling Tank 1.5 m x1.2 m x1.5 H(for cleaning auto acceseries)
Using HCL acid (dipping process). Actualy Iwant to scrub the gas from the
Tank. How can I calculate the capacity of the Blower to exhoust the gas
at what velocity and pressure. to remove the gas Give me repley.
Cherian
Re: gas scrubbing
10/14/2008 3:53 PM
typically you use a term called "change outs per minute or hour" This means you want to remove all the air above the tank every few minutes. So the vent hood is 2 meters over the tank, the volume is 1.5 * 1.2 * 2 = 3.6 m^3. I'd change out the air 2 times per minute = 7.6 M^3/minutes of vent capacity.
In the US we have specific rules on the changeout rate, so I'm just guessing on the time.
Good Answers: 101
Re: gas scrubbing
10/15/2008 12:16 AM
An air scrubber exhausts to atmosphere, so the pressure is approximately 1 bar or so. For the fan capacity, your room size multiplied by the number of required air changes per hour divided by 60 will give you the required flow rate per minute.
cherian (1); DVader1000 (1); vicini (2)
