Actually, Not. I have always felt that the "duty" in regards to heat exchangers referred to the thermodynamic heat transfer crossing a boundary. Energy. With respect to heat exchangers, the duty (I thought) was the Btu/hour crossing from one fluid of the heat exchanger to the other, as those are the units used. With feedwater heaters, however, I have found cases where that did not quite match. I thought, perhaps, that for a FWH, it only accounted for the energy in the extracted steam, and not the drips from the higher pressure FWH's. I am really not sure of the definition of "duty" for a heat exchanger, or for a Feedwater Heater in a Rankine Cycle. If someone has an official authentic definition in this regard, it would be appreciated. Thank You, sincerely.
Oh, I understand a little better what your looking for, and I can't help you. However a Google search of "Feedwater Heater in a Rankine Cycle" turned up some interesting stuff that might be of help. Good luck!
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
