Previous in Forum: Cold soak filtration   Next in Forum: Urea Fertilizer plants in the world
12 comments
What Material is This?
10/16/2008 2:30 PM
Dear friends:
I have a iron based material has the following chemistry: C: 1.2%; Mn 0.38%; P 0.039%; S 0.36%; Si 2.41%; Ni 0.39%; Cr 32.12%; Mo 1.99%; Cu 0.03%; Al 0.092%; B 0.0014%; Ti 0.02%; Cb 0.1%; V 0.08%; and Fe balace; Could you tell me what is the possible material is this? This is a material used in a bearing. Thanks!
Hobbies - Fishing - Popular Science - Paleontology - New Member
Good Answers: 27
Re: What material is this?
10/16/2008 3:12 PM
Offhand I'd say it's a complex chromium carbide.
What was the bearing used for?
Prophet Freddy has the answer!
Good Answers: 143
Re: What Material is This?
10/16/2008 6:25 PM
Did you look on matweb?
10/16/2008 10:59 PM
Hi, looks like the "Carbon Steel", do you use ABEC bearing?
This should be referring to the overall material of this bearing, similar to stainless?
Jason~Zen
Good Answers: 109
10/17/2008 2:08 AM
Ball-bearings - if stainless - are from 440C.
That has "only" 17% Cr.
What type of bearing in which application had the unknown material?
RHABE
10/17/2008 2:21 AM
Dear ;-)
Please don't investigate our materials, THIS IS ABSOLUTLY KNOW-HOW !!!
No regards
Good Answers: 94
10/17/2008 4:42 AM
The elements seem to fit with a chrome/moly steel with the chrome at the high end of the range. That would seem feasible for a bearing.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
10/17/2008 4:44 AM
According to the chemical composition it's a steel (not chromium carbide, even obviously they are in the microstructure), and must be stainless, rather martensitic and wear resistant what is expected in bearing steels, but I don't know a standard designation with such a high content of Cr.
Obviously you are in the US or made there the analysis because the use of Cb (Columbium) symbol instead of the IUPAQ official Nb (Niobium)
Kind regards
10/17/2008 6:01 AM
When i was in the US bearing industry, one of the major Japanese houses announced a proprietary grade of steel "better than 440C". This might be one of those.
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 25
10/17/2008 8:23 AM
Yes, it's one of the possibilities I considered because in my materials data I've found no similar C-Cr content.
Thank you
10/17/2008 9:59 AM
Try this: type 446 stainless steel from republic steel corp.-
Good Answers: 25
10/17/2008 3:33 PM
Type 446 SS has a maximum C of 0,2 and not of 1,2 and the Cr content is lower too:
Carbon0.2 max
Chromium23 - 27
IronBalance
Manganese1.5 max
Nitrogen0.25 max
Phosphorus0.04 max
Silicon1 max
Sulphur0.03 max
It doesn't seem the same steel.
Kind regards
10/17/2008 8:25 PM
Wright, it was the closest i had to that quantity of chrom in that moment then following the suggested above think matlab is the widest answer.-
Anonymous Poster (1); Duckinthepond (1); ferquiza (2); jasonzen (1); Kwetz (3); Nigh (1); RHABE (1); sidevalveguru (1); TVP45 (1)
