Previous in Forum: Question About Radio Waves and Interaction With Water   Next in Forum: Cable size for carring DC current of 65 Amp
Unearthed and Earthed grade
10/17/2008 12:36 AM
Dear sir,
Please let me know, what is the diffrence between the Unearthed grade and Earthed grade HT power cable?
My mail ID is bhupendrasahu_2006@yahoo.com
Re: Unearthed and Earthed grade
10/17/2008 12:55 AM
Sounds to me like you are talking about the difference between two wire conductor cable which carries phase and neutral currents (black and white insulation in the USA), and three wire conductor cables which carry the same black and white wires plus the green safety ground wire. This last is a non-current carrying conductor, except during electrical faults. The color standard might be different in India. In the EU, they use brown, blue and green with a yellow stripe, at least in power cords.
Good Answers: 42
10/17/2008 9:43 AM
Dear Guest,
It is more appropriate and advisable that you join CR4 as a member before putting up a thread iinstead of remaining an unknown Guest.More over you should use appropriate language in putting up a thread avoid use of language like "let me know" . This is supposed to be a forum where members share their knowledge free of cost.
This subject has been discussed in CR 4 time and again. If you have little patience to go through the earlier threads you will get your answer. Please read all the replies for the thread Dt. 08/21/2008
http://cr4.globalspec.com/thread/25644
After reading this thread please put up further discussions.
Regards
