Previous in Forum: regenerative breaking at asynchronous machine   Next in Forum: Neutral Current from 3-phase, 4-wire line connection
the CCD cameras
10/17/2008 8:34 AM
hello every one ! i got a little doubt about the CCD cameras my Q? is : can i use the ccd cameras as a sensor in some equipment to automatically trigger alarms
Regards !
Re: the CCD cameras
10/17/2008 9:02 AM
of cause you can !
in fact many alarms are consisting of cameras.
Re: the CCD cameras
10/17/2008 9:44 AM
thnx dear but if am clear, i don wan z camera to transmit video messages but just like any other analog or digital sensor( proximity,light,pyrometric......) can i connect this camera to a decission making part ( microprocessors, microcontrollers ..) directly to activate decissions like alarm activation... ??????????????????????????????????
thnx once again !!!
Re: the CCD cameras
10/20/2008 5:46 AM
Of cause you can. certainly can. no problem. if you would not be care of money.
you know the ccd camera is expensive than that a or d sensor like optic and dynamic etc. you metioned.
Second, if your microchip has a preamplifier, you can connect them directly, if not, you'd better use a preamplifier to enlarge the ccd output signal to match level, because the ccd signal usually is 1Vp-p. whereas michip is of 5v inputor say cmos (ttl) level. and then programming to judge.
if your group is rather rich, would you like to invest some to us?
Re: the CCD cameras
10/17/2008 10:20 AM
Try searching for Vision Sensors on Globalspec.com
Charlie don't surf.
Re: the CCD cameras
10/18/2008 3:05 AM
hey dear guest its better if u sign up ;
let me say some thing about this ccd cameras ; this are cameras which utilizr ccd (charge coupled device) sensors. the heart of this type of camera is a ccd imagera specialized type of IC which is located just behind the camera lens . the lens focuses small image of the scene infront of it directly on to the CCD imager chip which is behind the optical glass window in its package. the CCD imager scans the image and with the help of few support chips generate a complete standard video signal . hence we can utilize this signal to satisfy what ever needs of ours.
the overall working principles of the ccd imager is some what complex hence u had better browse the internet.
Re: the CCD cameras
10/20/2008 3:24 AM
Yes. They make very good cat, rodent and fox detectors. Cause for alarm? Let the user decide.
Anonymous Poster (1); cnpower (2); nastty (1); PWSlack (1); stevem (1)
You might be interested in: CCD Cameras, Video Cameras, High Speed Cameras
