Previous in Forum: Earth Fault Felay Setting: KASUGA-MH EM313   Next in Forum: reading material for parelleling generators
TYPES OF GENERATORS
10/20/2008 9:51 AM
WHAT ARE DIFFERENCE BETWEEN
1- STANDBY GENERATOR.
2-PRIME GENERATOR.
3-MAIN GENERATOR.
THANKS
Pathfinder Tags: generators
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: TYPES OF GENERATORS
10/20/2008 3:55 PM
The difference is basically in the name.
The two (2) main descriptions of generators are as follows: -
1) Main or Prime Generators are the Main or Primary source of power for the particular site.
2) Stand-By or Emergency generators are for when either the Main or Primary generator or Grid feed fail. These then start up and support the load.
In a multi-generator setup the first Generator may also be referred to as the Main or Primary generator as all the others are syncronised to it to parrallel them for large loads.
Having said all that, a Generator will quite often have two (2) ratings: Prime and Standby.
The Prime rating will usually be slightly less than the Stand-by rating as a generator running as Prime is designed to run 24*7*365 with minimal down-time for Maintenance, where as a Stand-By or Emergency Generator is expected to be sitting idle for 90% or more of its life but support a large proportion of its rated load on one hit very quickly.
Hope this helps,
Regards,
Sapper
It's all about the Boom! - MythBusters
10/21/2008 3:38 AM
thanks
10/23/2008 10:04 AM
Well said.I would only add that prime and standby ratings are due to prime movers ability.Like Diesel engine for continuous (Main /Prime) will be rated low as compared to stand by .
10/23/2008 10:27 AM
Caterpillar has three ratings namely...,
Standby
Prime
Continuous
The loading characterstics ( Load factor) is what decides the generator you need/specify.
There is an elaborate definition of load factor on CAT's website which you can refer.
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
Register to Reply 4 comments
chaterpilar (1); electrical engineer (1); nesubra (1); Sapper (1)
