Previous in Forum: Waterjet Control Program   Next in Forum: Help With a Mechanism
safe storage,handling and disposal
10/22/2008 7:04 AM
please explain to me how to ensure the safe storage handling and disposal of lubricants and why thanxs
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Re: safe storage,handling and disposal
10/23/2008 3:10 AM
Please, it is a veryy good link http://www.noria.com/catlink/storage01.asp.
Look over to the next challenge
10/23/2008 3:28 AM
Storage is often on bunded installations so that if the primary container leaks, the secondary container will provide a way of buying time to capture and contain the material while the leaking container is repaired or replaced.
Many lubricants are combustible, so this needs to be taken into account in the location and design of facilities. Disposal by incineration is probably the easiest, especially if the heat released can be put to good use.
How about looking on the 'net for Material Safety Data Sheets for the lubricant in question, and contacting the suppliers of each one for best practice advice?
Register to Reply 2 comments
