Previous in Forum: Cable testing   Next in Forum: Compressor Tripped on E/F During Motor Starting Only
Effect of Voltage Leakage
10/22/2008 3:53 PM
Hello all.
Please what is the effect of voltage leakage on an ATS panel or a Distribution board. How can it affect the performance of equipments connected to such ATS or DB?
Regards
One good Thing deserves Another
Re: Effect of Voltage Leakage
10/22/2008 6:32 PM
Describe in detail what you mean by voltage leakage.
Good Answers: 145
10/22/2008 9:50 PM
Also, it might be nice for the rest of us if you included the words so we know what "ATS" and "DB" are.
10/23/2008 5:01 PM
Hi all
ATS = Automatic Transfer Switch, Used to alternate the use of two or more power sources at a regular intervals or between a primary supply (usually public mains ) and a standby Diesel generators.
DB = Distribution Board (Consumer Unit)
By Voltage Leakage I mean having a residual voltage on Earthing cable ie the Earth - Neutral reading voltage value (While Testing with a Voltmeter)
Or
having electric shock by touching the bodies of such panels.
Engineering Fields - Power Engineering - Projects Engineer
10/23/2008 2:52 AM
It will further assist if you also indicate what type of leakage ,ie on control circuit or power side and the voltage involved.
ATS=Automatic transfer panel?
DB= Distribution board?
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
10/23/2008 2:59 AM
ATS = Advanced Tyre Services.
DB = Deutsche Bundesbahn!
Good Answers: 53
10/23/2008 12:39 PM
Never heard voltage leakage, do you mean voltage drop? or current leakage?
Register to Reply 6 comments
BruceFlorida (1); EnB (1); PWSlack (1); rakesh_semwal (1); SAK (1); wareagle (1)
