Previous in Forum: about transformer   Next in Forum: Query on SMPS
Design and installation of Grounding Ring
10/24/2008 5:04 PM
Hello All,
I need a guidance on design and installation of Grounding Ring (Earthing System) particularly on how to specify The Copper cable gauge, Earth Rod type, Earth Rod diameter/Length, Distance between earth rods, Minimum number of eath rods and Bonding type. I want to achieve a final earth reading of less than 5ohms. Iam in an area having a minimum of 20ohms earth resistivity. Thanks
One good Thing deserves Another
Re: Design and installation of Grounding Ring
10/24/2008 5:49 PM
Try Here.
Users' Guide to the National Electrical Code®: Understanding & Applying the NEC® 2008
1st Edition
Van Wert
Published by Delmar Publishers
PB 2008
ISBN/ISSN: 1-4283-4005-X
ISBN - 13: 978-1-4283-4005-3
"It is the mark of an instructed mind, to rest satisfied to the degree to which a subject admits itself, and not to seek exactness where only an aproximation of the truth can be found" Aristotle
10/25/2008 8:54 PM
You can use IEEE's green book for reference in grounding (earthing) systems.
Please check my Biography
10/27/2008 9:44 PM
please ref the IEEE guide for Safety in AC substation grounding (IEEE Std 80 -2000)from The Institute of Electrical and Electronics Engineers, Inc NY USA is best guide for designing the site specific requirement of earth mat design.
Register to Reply 3 comments
Benn (1); kasinikota srinivasarao (1); Paganini (1)
