Hello All,
I am looking to choose the right structural beam to use in a log splitter application. I will be using a 5"diam. x 26" stroke hydraulic cylinder with a max. pressure of 3000psi. (equates to about 30 tons unless my math is off). The beam needs to be approx. 7 feet long. The cylinder will sit on the flange with its centerline 4" from the flange surface. I'd like to use a wide-flange ("W") beam.
I'd like it to be "bulletproof" but don't want to go overboard with weight.
Thanks in advance for any advice
