Previous in Forum: difference between Allan cap and Hex cap   Next in Forum: Log Splitter Beam
centrifugal pump ?
11/03/2008 6:40 AM
Hi, friends, this is a specific case of centrifugal pump selection requirement, where static head may vary from 96 mlc. to 55 mlc. Normal operating duty point of a pump with 96 mlc. static head difference and available NPSH 21 mlc is 110 m3/hr @ 109 mlc. Can any one elaborate , what will happen if the same pump shall operate in the same system, which is rarely but may occur with static heed difference reduced to 55 mlc due to flood level in inlet pond ?
Re: centrifugal pump ?
11/03/2008 7:39 AM
The flowrate will be greater than 110m3/h, and the pump manufacturer's model performance curve will indicate by how much.
A centrifugal pump operates where its performance curve and the piping system characteristic curve intersect.
Good Answers: 97
11/03/2008 10:53 AM
You can determine crossing point of the pipe system curve and the pump delivery curve. The friction component will rise due to higher flows.
Most pumps will need more HP. The efficiency is also mostly lower at this point.
If you now choose your driver big enough to cater for this high power requirement your system can run unattended at varying heads.
Alternatively you can install a flow regulating valve.
01/08/2025 7:43 AM
Invitation declined.
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
11/04/2008 1:57 AM
Please have a look to pump curve versus system curve.
Look over to the next challenge
Hendrik (1); PWSlack (2); user-deleted-1104 (1)
You might be interested in: Centrifugal Pumps, Ionizers and Static Eliminators
