Previous in Forum: hydrogen storage   Next in Forum: Temperature and PU Density
Coupling
11/05/2008 3:19 AM
One side of FNPT Coupling (2") is connected with threaded pipe ( 2" , A53 , Sch160 , Type F , FBW , Galv ) & other side with concentric swage ( 2" X ¾" , TBEM , A234-WPB , S160 , Galv ) . There are two options of 2" , FNPT , Galv , coupling in Piping Spec – One with A197,Cl 300 & other with A105,Cl 3000 . Service is cooling water supply / return , Threaded spec , Corrosion allowance is 0.125" , no insulation , Design Pr. & Temp. are 150 psig & 170 F. Pl. tell the correct option & tell whether selection from these two options depends on Design conditions also .
Thanks
Be simple and specific for a great success in Life
Good Answers: 61
Re: Coupling
11/05/2008 11:29 AM
You wrote:
"There are two options of 2" , FNPT , Galv , coupling in Piping Spec "
You should find out who wrote this Spec and why he or she put in two options.
There is nobody out here who can answer that question.
Do it once and do it right
You might be interested in: Threaded Inserts, Threaded Rod, Flexible Couplings
