Previous in Forum: Coupling   Next in Forum: Heating Sulphuric Acid (H2SO4)
Temperature and PU Density
11/06/2008 2:05 AM
I have a panels PU continuous line, the pre heating temperature is 45°C and the double conveyor belt is at 65°C. I need to know if the temperature affects PU density?
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
Re: Temperature and PU Density
11/07/2008 4:28 AM
the PU reaction is exothermic ( gives off heat)
the reaction also creates CO2 which lowers the density by creating gas
you may remember from chemistry PV=nRT
pressure x volume = constant x Temperature
depending on your surfactant package:
if the belt is colder then the material will be denser on the outside layer than in the core (becomes a structural type foam)
which will increase the overall density
hope his helps?
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
11/07/2008 7:04 PM
Raising or lowering the temperature will change the internal pressure.
But if the dispensing rate is constant and the panel thickness does not change, the PU density must remain constant.
PU density is mass per unit volume.
As soon as the PU reaches adequate cure, the internal pressure can no longer change the density.
Register to Reply 2 comments
