Previous in Forum: Torque Transducer Under Vacuum   Next in Forum: Flanged Transmitter
glyserin filled Pressure Gauge
11/06/2008 12:40 PM
What is the crieteria to use glyserin filled pressure gauge on pump discharge side?
Re: glyserin filled Pressure Gauge
11/06/2008 4:47 PM
Most pay the extra cost for Glyerin Filled gauges since they think they last longer than the ones without the dampening effect of the oil.
I recommend and specify on any circut I design that all gauges have a Push to Read 3-way valve between the gauge and the pressure source. They are called Gauge Isolators and are sold by most Fluid Power distributors. Most have a Twist to Lock Open feature that I don't like since they usually get Pushed and Twisted and stay that way and now makes the Isoator an expensive piece of PLUMBING.
That means the gauge is never under pressure unless someone is holding the Push to Read Button and the Gauge reads correctly for the life of the machine unless itis physically damaged or ocver pressured.
I also use a non filled gauge since it responds faster and makes reading pressure spikes a lot closer to the actual spike pressure.
Bud Trinkel
11/06/2008 11:48 PM
hi dear
we can use push to Read valve its ok. but what if the system is under continuous vibration then isn't it necessary to use oil filled guages for damping? please comment
11/07/2008 6:17 AM
Another way to cushion the gauge is to use a snubber -a tiny hole in a blanking plate in the line to the gauge that cushions the gauge against pressure fluctuations and helps it to read, steadily, the time-weighted average pressure.
Local practices and company piping standards vary.
11/07/2008 8:51 AM
"we can use push to Read valve its ok. but what if the system is under continuous vibration then isn't it necessary to use oil filled guages for damping? please comment"
Never had that situation. I would think the least problem would be with Gauges in that case.
I believe if Gauges were being damaged by vibration I would be using Quick Disconnects with Protective Covers and use a Gauge from my Tool Box to check pressure. Pressure Transducers with Feedback to the PLC would also work.
Bud Trinkel
11/14/2008 3:54 PM
Use a remotely mounted gauge mounted on a non vibrating stand or surface.
jf
Anonymous Poster (1); BudT (2); PWSlack (1); RAJ KUMAR (1)
You might be interested in: Pressure Gauges, Pressure Sensors, Pressure Switches
