Previous in Forum: CALCULATION OF PERCENTAGE IMPEDENCE   Next in Forum: Power Factor
8 comments
Detecting Momentary Dips in Current
11/07/2008 1:27 AM
I want to monitor momentary dip in current by some electronic system, how to do it?
Re: how to detect momentary dip in current
11/07/2008 5:47 AM
How about an ammeter linked to a chart recorder?
11/07/2008 9:35 AM
or an oscilloscope with a current probe.
Good Answers: 73
11/07/2008 9:40 AM
It helps if you know how short the "momentary dip" is likely to be.
A current transformer (CT) is the best device for signal detection.
The sample rate of your monitoring needs to be no less than 10 times as fast as your fundamental frequency (of the AC waveform or event, which ever is fastest). Or, you can convert your AC level into a DC voltage with a response that is faster than your change in current ("current dip"). More description would be helpful.
By some electronic system, your choices are: chart recorder, data acquisition system, alarm device, op amp comparator, and so on.
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: Detecting Momentary Dips in Current
11/08/2008 7:08 AM
I would ask these questions of you:
1. How will you use the information?
2. Will you be alarming some process, shutting down a device or controlling a process?
3. How much are you willing to invest in the monitoring system?
If your budget is simple and inexpensive, a current sensor with chart recorder as explained above would suffice. If you will be controlling a process, I suggest a SCADA system or PLC with the appropriate end devices and data aquistition to measure, record and control. It all comes down to how much you want to invest.
You may contact me for a detailed design based on your requirements.
"Memorize the calculations, you look like a fool searching your notes while teaching class"
11/08/2008 11:50 AM
Greetings.
There are a number of electrical monitoring devices that print out a graph, or give data output that tell high, low, dropouts, etc.
E=IR, P=IE
E=Volts, I=Current in Amps, R= Resistance, P=Power in Watts
Depending on your budget Fluke has a 3 phase power Power Quality Analyzer. Also a clamp on single phase model 345 that is a combination meter.
AEMC SDL V401 is a 4 channel data logger with software.
Look at PQMeterStore.com
11/08/2008 12:31 PM
"fluke power analyser" is the only solution for your situation
Good Answers: 53
11/08/2008 1:02 PM
Depends upon how momentary is the dip but you can try this circuit.
Put resistance Rs in series to current path,Voltmeter will show an upward deflection from few seconds to many seconds.
11/10/2008 1:56 PM
Regards:
As asked above:
I will add:
Dip in which type of Current? AC or DC ?
You really mean CURRENT or talking in general & mean Voltages?
look in Power-Monitoring Equipment Section if to check Dips, Brown-outs, Black-outs in Utillity Power.
There are Recorders for this purpose in the Electric-Power market, with paper shart-Recorders; running
a role of paper 2 very slow-speed; & prints all the parameters of power-conditions.
A single small unit; having back-up memory for time & data; recorder runs on power.
Regards
Register to Reply 8 comments
Anonymous Poster (1); bhankiii (1); Haajee (1); jcchiefeng (1); NotUrOrdinaryJoe (1); OlympiaWA (1); PWSlack (1); rakesh_semwal (1)
