Previous in Forum: Encoder Siemens Motor   Next in Forum: motor reaccelaration
10 comments
Inductance in Coils and Shafts
11/07/2008 10:57 AM
hi,
I have a electrical basics question.
Is the phenomenon of inductance prominent only in coil form, or can one see it in solid shafts as well? (like a current carrying copper shaft) ?
thanks!
Re: electrical basics query
11/07/2008 11:01 AM
Any conductor carrying current (and therefore creating a magnetic field) will exhibit inductance.
Charlie don't surf.
11/07/2008 11:19 AM
Yes it is exhibited in any current carrying conductor. It is prominent when conductors are placed in such a way as to concentrate the magnetic field (such as a coil) or when signals are of sufficiently high frequency that the parasitic inductance of ordinary conductors becomes a major concern in propagating the signal.
Good Answers: 230
Re: Inductance in Coils and Shafts
11/07/2008 5:11 PM
Hello vscid
As explained by others above, every current-carrying conductor exhibits inductance.
Here is a UHF circuit board, in which the two arrowed printed copper strips act as inductances at the operating frequency.
As you can see, the "strip line" inductors just look like a normal part of the actual printed copper connections.
At 100MHz a hairpin (U-shaped) piece of wire of the dimensions of an ordinary paper clip has an impedance of approximately 100 Ohms, caused by the inductance.
Both transmitting and receiving antennas rely on the relative Capacitance and Inductance of the wire or elements to transmit or receive a signal efficiently.
Kind Regards....
11/07/2008 9:31 PM
Dear All,
If there is an electrical current, the current induces a magnetic flux.
Inductance is a ratio of this flux (Wb), to the current (A).
So, in any form of conductor, coil or solid shaft, there is a inductance.
A coil has higher inductance the a solid shaft.
Regards
Akihito Shigeno @ JGC-Indonesia
11/07/2008 11:44 PM
I am CoronaCameraMan -
Are you referring to shaft currents ?
Some, usually synchronous generators or motors can have shaft currents which require one of the shaft bearings to be isolated from the generator frame at the mounting. This insulated bearing housing is difficult to test the quality or integrity of. Without the insulated bearing housing some units will quickly ruin bearings.
Good Answers: 58
11/08/2008 7:48 AM
Whenever electric current flows, inductance is involved. A gentleman by the name of Frederik W. Grover devoted his career to inductance calculations and wrote a book by that name (ISBN 0-486-49577-9). Between self, and mutual inductance, the book covers any situation you are likely to encounter.
Good Answers: 12
11/08/2008 10:41 AM
If you are using low frequency, straight lines produce almost no inductive effects unless the current is very high, but I have seen power lines and welding cables move from major short circuits. The comment about bearings being damaged by current ( if you're working with a rotating shaft) is a real concern.
11/08/2008 12:10 PM
Rebuilt,
What is defined as 'high current' in reference to presence of significant inductance?
Good Answers: 58
11/08/2008 4:35 PM
For example, we build low frequency resistance welding equipment that delivers 200,000 amperes into a short circuit. At those current levels, nano-henries are important.
Good Answers: 12
11/09/2008 8:46 AM
Sorry if i confused with my statment. I don't consider " inductance " to vary. Inductive effect implies motion in this case. Considerable current to move wires could be a lot of current like several thousand (or perhaps hundred thousand amps). Sometimes my communications skills let me down.
Register to Reply 10 comments
Akihito Shigeno (1); Anonymous Poster (1); bhankiii (1); Rebuilt (2); Sparkstation (1); stevem (1); vscid (1); welderman (2)
