Previous in Forum: Floor Drain & Trap Gully   Next in Forum: balll valve selection
12 comments
Metallic bellows avoiding seals in pumps
11/08/2008 6:56 PM
Did you ever know who makes or made any pump like this?I made every kind of calculations,fatigue included and when small flux is involved and so high pressure the toroidal metallic bellow should work.Isn't it?could avoid every plastics seals!!
Re: Metallic bellows avoiding seals in pumps
11/09/2008 9:33 PM
I've seen some of those kind of pumps with diaphragms made of stainless steel for pumping chemicals with contaminants. They work fine with plane elements, not thoroids. To help reduce the stiffness, they are shaped like the waves in water surface when you drop a rock... if I made myself clear...
Humm... suspicious you are...
11/15/2008 8:06 PM
That's great.Could you give me more information about like who makes or made ....
Good Answers: 58
11/10/2008 9:03 AM
I have an application for such a pump. If you find one, please let me know. In the meantime, Metal Bellows Corp. in MA makes a similar one that uses a metal bellows. Not as elegant as yours, but it works well.
11/15/2008 8:08 PM
Sorry you said in MA...What's MA?
Good Answers: 58
11/17/2008 7:50 AM
You can lead a horse to water------never mind.
Senior Aerospace Metal Bellows
Senior Operations LLC
1075 Providence Highway
Sharon, MA 02067
800-BELLOWS
TEL:781-784-1400
FAX: 781-784-1405
http://www.metalbellows.com/products/compressor-pump.html
Good Answers: 94
11/10/2008 10:25 AM
That looks like a very stiff shape to actuate, wouldn't a linear bellows work better?
11/15/2008 8:13 PM
This is a small displacement, the kind of just one unit you show.
Good Answers: 94
11/17/2008 5:30 AM
How small? I have bellows down to about 2mm diameter x 4mm long.
11/11/2008 5:19 AM
Dear
There is equipement details is must like the pump manufacturer, suffing box details,shaft dia,Media details like pumping,liquid,temp,pressure,suction and discharge,viscosity
Ther are so many seal manufacturers in India
you can contact to
Leak proof engg
F-1 laxmi industrial Estate
Azad nagar Mumbai
Good Answers: 109
11/12/2008 11:21 AM
Hi,
these pumps are typically used for metering fluids (water disinfection and other chemical dosing for example).
LEWA and PROMINENT are producers in Germany that deliver worldwide.
RHABE
Good Answers: 58
11/12/2008 12:06 PM
What you have sketched looks a lot like a metal version of a rolling diaphragm made by Bellofram Corp. Google them if you want more information.
11/15/2008 8:17 PM
OK FRIENDS,i 'll check lewa prominent and bellofram.I am Ferquiza in hollydays and i couldn't thank you your information we'll se now..
Register to Reply 12 comments
Anonymous Poster (5); bhrescobar (1); Nigh (2); RHABE (1); welderman (3)
