Previous in Forum: quantum entanglement and cold nuclear fusion   Next in Forum: Glass Technology
25 comments
replicate my experiment for truth- i solved energy crisis
11/09/2008 6:36 AM
Hello, my name is Solomon Azar- I HAVE FOUND THE ROAD TO SAFE CLEAN NUCLEAR FUSION- When this is found and understood- the energy crisis will end- I have been looking at this system since 2002 and it is perfect in every way. I finished my experiments April-2007. I have since that time tried to the best of my abilities to inform many people upon the net- there is no question It would be nice if concerned citizens would offer suggestions or help provoke a university to simply repeat my experiment to end the energy crisis- 19 months and I still wait as the world crumbles from lack of abundant clean energy.
I have performed an experiment never done before in science- I used a Tesla coil for its use in high voltage high frequency and apply its discharge plasma not upon the dielectric of free air- but to the dielectric of water itself- specifically I used ultrapure reagent grade water from manufacture NERL-this is to establish the high degree of insulation needed for plasma (you cannot have contaminants for conductivity)- I doped my water with heavy water from the manufacturer UNITED NUCLEAR-(however- a full concentration of heavy water is desired)- I built my 1 million volt Tesla coil entire tunable- every aspect of it- as it must be done to TUNE THE OUTPUT DISCHARGE OF THE TESLA COIL to the water itself- once the arc is stable- the voltage may be increased- I have written in my pdf file in my website of noblefuse.com that a prerequisite of 750 kv is needed as an electric field gradient about the charged particles used in fusion( in this case the hydrogen bound in the water molecule) because of voltage drops as expected as in all electrical systems upon the load (load here is the water)- a much higher voltage is needed in order to distribute the voltage gradient upon entire arc plasma length between electrodes in water- THUS- THE HIGH THE VOLTAGE- THE BETTER- within my website you will find a link to youtube showing my primitive experiment- BUT MAKE NO MISTAKE ABOUT THIS- THIS IS THE FIRST TIME EVER DONE BEFORE - I propose nuclear fusion of water/heavy water- my little experiment IS THE ROAD TO NUCLEAR FUSION- we must universally connect the dots- put two and two together- and conclude this- MY EXPERIMENT MUST BE REPEATED ON A LARGER SCALE- my system is a direct replacement of nuclear power plants particularly of the pressurized water reactor which uses heavy water already - a vessel already built for gamma radiation and other high energy flux which will emit with the plasma arc-
Power reactor in which the heat is dissipated from the core using highly pressurized water (about 160 bar) to achieve a high temperature and avoid boiling within the core. The cooling water transfers its heat to the secondary system in a steam generator. Example: Grohnde Nuclear Power Plant in Germany with an electrical output of 1,430 MW.
Replace the rod assemblies and use electrodes to conduct the Lightning bolt! High Voltage High frequency will create the magnetic pinch to slam the isotopes of hydrogen together which is bound in water- helium and oxygen are the outgassed products recaptured by expansion tanks-it is absolutely perfect!
_ I HAVE FOUND THE TRUE PURPOSE OF THE TESLA COIL- the answer was always in the lightning bolt- understanding of gamma bursts from lightning discharges have only been recently vindicated from satellite in late 90s---
CA 94305 United States
Said, R ( ) , STAR Lab, Electrical Engineering, 350 Serra Mall, Stanford, CA 94305 United States
Smith, D M ( ) , Physics Department and Santa Cruz Institute for Particle Physics, University of California, Santa Cruz, 1156 High Street, Santa Cruz, CA 95064 United States
Lopez, L I ( ) , Astronomy Department and Space Sciences Laboratory, University of California, Berkeley, CA 94720 United States
The observation of brief (<1 ms) bursts of intense γ-rays, the so-called Terrestrial Gamma-ray Flashes (TGFs), by the BATSE γ-ray experiment was one of the most unexpected discoveries by the Compton Gamma-Ray Observatory.
Let me try to give another analogy to make the point. think about striking a match, if all conditions are proper , one knows that to strike a match, you must go a minimum speed- you cannot strike the match too slowly- this is understood as more speed is more friction and thus more activation energy necessary to create combustion of the match material. the same applies to this fusion system, first, imagine my system as inside a pressurized water reactor used in fission plants- the moderator is already heavy water- we shall use it as the fuel. I have said the plasma arc looks exactly like our friend the electric lightning bolt- but I talk about in my pdf file- that the so called lightning bolt must be understood in regards to high voltage and frequency- just like the minimum speed needed for the match- so it is with the combination on high voltage and frequency to not only resonate with the dielectric molecule of heavy water- but more so- to create a minimum velocity upon charged particles in the fuel water. this velocity is also exhibiting itself as a magnetic field-think of the cathode ray scope- in a snap shot instant in time for analysis, look at when the maximum energy is being applied on a per strike basis of the input cycle- or shall we say the highest amplitude of the ac signal. if for example- an input energy of one megawatt was injected into the strike of the arc- a magnetic pinch shall be directed upon the charged particles in transit of the discharge- in a thermodynamic extraction process such as this - we need at least 5 times more energy out of the system to recoup our initial energy input- and a surplus for commercial energy supply- thus- via fusion of hydrogen to helium- with each strike- a minimum voltage and frequency SHALL give the minimum activation energy required for magnetic pinching and fusion of the isotopes of hydrogen. to increase the q of the reaction in this system- a magnetic toroid may be used around the plasma arc for increased efficiency= such as used in tokamak devices. I hope this analogy helps those who question this system- THANK YOU--
Here is a thought experiment for electromagnetic fusion with Einstein in mind
Pretend you are water-you are an oxygen atom- you are stable- you are noble- 8 protons-8 neutrons-and 8 electrons- there are only 5 magic shell nuclear elements of the periodic table- oxygen is one of them- it is very stable-
Therefore- you are stable and noble- you have no need for fusion- yet it could happen- but the probability of another element such as hydrogen and its isotopes would be made to fuse together in some kind of fashion mankind tries will occur way before oxygen does- - ok-so now you are this noble one and you have outstretched in your hands a hydrogen atom and or its isotope deuteron and you hold it out to mankind as a gift-
Man understands the gift of fusion for many years and is desperately trying to do such-
I propose electromagnetic fusion- I propose the BENNET pinch used in poloidal currents used in plasmas of tokomaks- but much further-
Here we go – the thought experiment- you are this oxygen atom with two hydrogen's and you stand amongst your friends similar in nature. You are placed in a large vessel filled of your kind-now imagine that two walls opposing in this vessel are the plates of a capacitor- who cares what is applied to the capacitor plates (electrodes of system)-for all you know as a noble oxygen and the hydrogen you have in your hands is nothing more than the electric field upon the plates-
You are composed of charged particles- thus you will interact with the applied electric field of the plates-this is common electronics and electric knowledge-
However, I speak of dielectric breakdown- I speak of the lightning bolt- let us now assume we have made the capacitor plates oscillate at 1 million volts peak to peak as way of a tesla coil
Think of the electric field- everything will be controlled by this field- a dielectric breakdown will occur- and all discharge current will begin to flow and oscillate as a function of the applied voltage-
Now- you are in the heart of a lightning bolt- you who are noble as a oxygen probably lost all your valence electrons due to the magnitude of such a high electric field- every charged particle in transit of the discharge current is surely ionized and talks of being a complete water molecule should be erased- the state of this plasma current is nothing more than ionized hydrogen and oxygen and a complete sea of electrons-
Let us think first of the electrons- 1896 times smaller than protons- no question it will oscillate much faster as a function to the applied voltage- remember the cathode ray scope- basic physics also will say this charged particle will also have a magnetic field about itself because of the electric field that has driven it-thus- this oscillating electron current will have an intrinsic magnetic field
Let us now think of the protons- oxygen has 8 and surrounded by 8 neutrons and is far less likely for reaction than isotopes of hydrogen for fusion- this should merely be understood by refereeing to atomic tables of elements and known theory- but this hydrogen is a singly bound proton with mass one- unless we speak of a deuteron- it will also be controlled exactly the same way as the electron is affected by the external applied voltage- however- it is opposite to the electrons motion-and much slower by its mass – however-its magnetic field will add to that of the electrons- this is standard knowledge of magnetic field generation of charged particles by way of electric fields-
Thus, in this thought experiment- within this state of dielectric breakdown- I like to say the lightning bolt- can you now see the oscillation of the charged particles by such a large magnitude of the applied voltage plates- can you now see the probability at a certain moment in time- particularly when the applied ac signal is greatest- that all magnetic fields of charged particles in transit can have the power to be magnetically pinched-
Magnetics have push and pull- it is well known that high frequency causes a constriction upon electrical currents- whether in copper lines and forcing such to the surface- or in plasma and made use to constrict it - high frequency is known to constrict the currents- thus- do you see the forces I am referring to as this dielectric breakdown has occurred upon the most perfect fuel of the heavens- water- this oxygen atom holds the hydrogen for us- we shall apply a high voltage (high is relative- I have stated 750kv in the vicinity of the hydrogen for fusion- I come to this by way of understanding the beta decay of a free neutron- if it can disintegrate- it can come together- made into a deuteron- then made into helium)-
Thus –we make helium and oxygen is then unbound and must also be recaptured- this is easy in expansion tanks- the byproducts are helium and oxygen-truly noble-
To increase the q of this system- a simple toroidal magnet as used in tokamaks for plasma control may be used for additional pinching-
I hope this helps- however- you must always think of the applied electric field and its magnetic inducement upon the charged particles- we will stably run the Tesla coil upon the dielectric of water itself (more appropriately heavy water) and turn up the voltage for greater acceleration speeds and thus magnetic fields- we can control pressure in this vessel- we can control electrode spacing and so much more-
that is my thought experiment for you to understand it is my intention to use all input energy by way of oscillating a very large electric field which will induce the proper magnetic flux density in units of Tesla for a pinching- not established hot fusion whereby all energy input is chaotic and the probability of fusion comes by way of statistics from a gas equation- no- high voltage and high frequency in an orderly manner by the construction of a man made lightning bolt with controllable parameters inside an existing pressurized nuclear reactor- everything is off the shelf- the world will run on steam power again globally-from trains-factories-ships-and all power plants- I offer the Watt steam engine again- not with two sticks to make fire and boil the water- but electromagnetic fusion with two electrodes to induce fusion of hydrogen isotopes to boil water and make steam- it is absolutely perfect.
To the CEO's of nuclear power plants-or pressurized coal fired- you have spare reactors in the back yards of your plants- take a 1 million volt tesla coil and do what I have said- you will measure its fusion reactions and you will conclude this - I have found the road to safe clean energy.
I speak plain science- please connect the dots and let us end this energy crisis for a world that desperately needs energy- May the light of God shine upon all our actions for the betterment of mankind
Solomon Sami Azar
update-after 19 months on this net- it seems evident people do not care until the machine breaks, right before our eyes our economy collapses as inflation and energy costs have been eating at our economy for some time now- maybe even global war with russia and iran will you finally care to investigate the deeds of a human being that has sacrificed his life over a dangerous experiment for all of us. Time will tell.
Nov 8- 2008
This discussion was "closed" on 11/10/2008 2:18 PM. No new comments are allowed.
Message from admins:
User has been asked two simple questions which would make his claims possible. He refuses, claiming all manner of persecution. We're done here.
Good Answers: 53
Re: replicate my experiment for truth- i solved energy crisis
11/09/2008 8:00 AM
Roger Pink Your dream comes true!
Good Answers: 243
11/09/2008 7:17 PM
Way to many words in this post to try to follow.
Please just provide us with the following facts:
1) HOW MUCH ENERGY WATTS OR JOULES DID YOU INPUT INTO THE APPARATUS?
2) hOW MUCH ENERGY IN EXCESS OF THIS DID YOU RECOVER FROM YOUR APPARATUS.
Thanks
Milo
11/09/2008 7:37 PM
thank you- the facts are i have performed an experiment never before with a tesla coil for the ENERGY CRISIS. my measurements are small as i used junk yard parts and went bankrupt to this stage- i run across net instigating so a university or something replicates for truth- in 19 straight months- noone does anything but ignore or ridicule- no wonder man goes to war- no wonder greed and stupidity destroy the markets- those are the facts- when you want the energy crisis to end- thrid party people like you will instigate- so far noone does anything- i am limited after experiment to just type and instigate- facts-
Good Answers: 101
11/10/2008 12:06 AM
Nobody will ever take you seriously if you go about making conspiracy theory allegations instead of answering straight forward simple questions. How much energy did you put in, and how much did you recover? How much did your equipment cost, and can you replicate the experiment before a panel of experts? If not, then can you provide the details to an independent testing body for them to replicate it? If there answer to any of these questions is no, then don't expect anyone to listen to you. There have been far too many scammers and crackpots who have made similar claims and yet refused to back them up with proof.
11/10/2008 9:07 AM
if you actually spent more than 15 minutes reviewing my sites- you would see i hand built a one million volt tesla coil for proof- yes it is repeatable- but in 19 months i have found i now live in a world of atheistic monkeys that have lost sight of god- this means people are not only greedy in wall stree for crash- but also on net and even amognst friends and strangers where another human being solves a solution only to be ignored ridiculed - just like party politics where the fate of a nation is ignored by one side at times-
here is my prediction- the american economy will fully collapse- probably war with iran and or russia for new oil fields and thus plunder of assets for american wealth as thewir citizens are to ignoirant to fix the solution themselves- just kill your neighbor for quick fix- after so much degradadtion- people like you and all other sellfish idiots for 19 months will finally spend that 15 minutes-then the energy crisis will end- i did it- nuclear fusion of isotopes of hydrogen bound in heavy wayer- the lightning bolt with a tesla coil- a shame a wonderful new experiment is ignored just because people dont like when someone does something they havent- time will tell
Register to Reply Off Topic (Score 12)
Good Answers: 101
11/10/2008 11:40 AM
You either cannot comprehend or refuse to comprehend what I'm saying. If you want people to believe you, either get a reputable third party to repeat your experiment, or perform it yourself before a panel of credible witnesses. I can claim to be the Incredible Hulk if I wanted to, but how true is it? I personally would be all to happy IF cold fusion is really achieved, but in all these years, no one has ever provided irrefutable evidence that they have actually done so. If you really are the first, then please prove us all wrong before the entire world instead of resorting to childish name-calling and irrelevant ranting.
And as for me being jealous and selfish, a project I did recently won a major award in my country. I am also now in the middle of planning another major project that has made the news. My chief interest is in water engineering and environmental remediation, not cold fusion, so I have much better things to do than throw a hissy fit over someone who claims that he's surrounded by atheistic monkeys who lost sight of god, who wouldn't happen to be you now, would it?
By the way, if you have really achieved cold fusion, why are you still alive? Wouldn't the heat energy and gamma radiation released from the reaction have killed you? And how did you get ahold of heavy water anyway? The only use for heavy water is in nuclear energy, so it's not available for sale to the general public.
Just for your information, my sole interest in this thread is to ensure that no innocent person gets scammed. I've done the same thing to other people who have made outlandish claims but refused to prove it. So if you can prove all us sceptics wrong, I'll eat my helmet.
11/10/2008 12:26 PM
sir- respectfully- i have found in 19 months that my sincere and agressive tactics to uncover this experiment have been ignored and ridiculed because viewers do not like me personally because my answers are not to their liking- because of my personal beliefs- because of many personal reasons to a viewer as they ask question- i did as much as I can with writing a pdf paper to the best of my capabilities which i try continuosly to have peer reviewed- i show all my experiments for free on youtube which shows demonstration of unity- my sensors and measurment shouldnt be trusted as did pons/flieshman- yet- please repeat this- the cold fusion community has ignored this- the hot fusion community ignored it as i say water- i ran complelty broke- thus- another personal garage inventor like me will run broke and scream to public like i do- i am trying to instigate a credible university to repleicate themselves- am i the only one on planet earth that can tune the output discharge to heavy water- i dont think so- but a fire must go under your ass to do this- beccause of pride and vanity- just like party politic partisans- i am ignored and abused during this period-maybe economy must completly collapse before people like you spread this experiment so it may be repeated- in 19 months- noone has ever done so- that is what hurt the most0- tesla philes just ignorte this and they love the man who try to solved the energy crisis- i give them an experiment never before in 100 years with coil and nothing- i am sick of living with full belief i have solved energy crisis- if only one descent human being would try to help uncover this experiment and prove right or wrong- i am a one man show-type on compuytet by myself with no campaign tean or finances to make experiment better with more sensors and better neasurmnents- I RAN BROKE- this is nuclear fusion-= i found the door- you people go insider and end the energy crisis with no greenhouse gases with the most abundant fuel on the planet- hydrogen- bound in the arms of oxygen- perfect-water- respectfuly sir- i am sick and tired of doing this- i can only do as much as a one man show with no finances and the luck of stilling having computer access to try my best to have uncovered before economy gets worse- i am trying-
peace
11/10/2008 12:37 PM
Your previous postings full of vitriol does little to further your cause.
Good Answers: 243
11/10/2008 12:44 PM
For what its worth, I just went through the 46 page pdf and there are no data tables.
I did find a site whereby our poster claims to be the messiah...
http://www.brightcove.tv/channel.jsp?channel=1417400192
Please take it someplace else.
I'll not waste any more time on this one.
milo
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
11/10/2008 1:02 PM
Some good digging there milo, a GA for that. It is good entertainment for a Monday morning though....Geez, our own messiah right here at CR4, I'm humbled.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Hobbies - HAM Radio - VE6LDS Popular Science - Weaponology - New Member Canada - Member - New Member Engineering Fields - Nuclear Engineering - New Member
11/10/2008 1:51 PM
Actually there are places that will sell small quantities of heavy water, A few ml at a time. Industrial quantities go for about $300 per Kg.
Semi-retired systems analyst, part time Ham radio operator, full time grandfather.
Good Answers: 243
11/10/2008 10:08 AM
'How much energy did you put in, and how much did you recover?'
"No data here, this guys got nothin""
"Last chance, where's the data?"
milo "duces tecum"
Good Answers: 183
11/10/2008 6:11 AM
There are a lot of storms in the earth atmosphere and a lot of water vapour or even water droplets when between clouds or clouds and earth such huge discharges occur. If what you claim is true (and I do not say that you are right or wrong as long as it is not proved either way) then it should not exist any H atoms and as well no water since they should have been all burned by fusion.
Please explain.
By the way all comments go to same direction :
have you made a real (even small) test or is it only a "brain test"?
Have you quantified how much energy you put in and how much got out? Even on a small scale with, as you say, junkyard equipment?
There is no conspiracy as many want to believe to explain their un-success. If you did not get support it is because you were not able to convince those people that it is worthwhile investing the money and effort in a professional fixture and a professional test.
11/10/2008 12:32 PM
thank you- i was not able to convince- i am one man show- i believe the delay in uncovering was due to stating my personal reliogous beliefs upon net- i figure if bill maher and others can proudly proclaim there is no god and laugh at the idea of christ on the net- i can do what i believe in free will- I love the christ-
thus- vanity and pride will hinder this experiment like refusal for first bailoit plan on america- one side doesnt like the other- YOU people dont like me becaue i do not write to your pleasing-thus- economy dies-
The Engineer
Good Answers: 129
11/10/2008 10:04 AM
Noblefuse,
Have you tried submitting this to the ArXiv.org e-Print archive? You'd have to write a paper with more technical details but then it would be reviewed by the scientific community.
It's hard to judge your device when you don't provide any input or output energies. Fusion isn't difficult to achieve, it's a sustainable Fusion reaction with more energy out than put in that is difficult to achieve. From everything I've seen that you provided, you in no way indicate that you're getting more energy out.
I'm looking forward to your responses. Please make them technical (i.e. data), please don't give anectdotal evidence and qualtitative explanations as they are the scientific way of saying "take my word for it".
Good Answers: 243
11/10/2008 10:09 AM
Good answer.
milo
The Engineer
Good Answers: 129
11/10/2008 10:37 AM
I would hope you liked it, I stole that energy in, energy out bit from you
Good Answers: 243
11/10/2008 10:48 AM
While that may be true, I thought that you were really doing the original poster, and all of us, a favor by "teaching him how to be effective."
Thats for the "good of the order" and so the GA.
milo
11/10/2008 12:38 PM
thank you sir- i will try- as for rewriting- i did enough- why nature and others have refused AND NEVER offered where to go or rewrite another way- i did enough- someone else write in and submit it in your name- i said this for 19 months- i have pdf and will try- i tried to make it general enough for science understanding- it will take time- a new ideology- the catalytic cleaving actions of cold fusion(what do you expect-they are chemists) i propose real fusion within state of plasma itself of heavy water-i have tried to be civil and polite for 13 months- i now try the slap in the face approuch as our economy crumbles and our soldiers battle for energy-i am trying- thank you for suggestion- i will try for 100th time again alone
11/10/2008 12:41 PM
actually-can you try- noblefuse.com/nfg6.pdf
or rewrite in your name on new way to tackle fusion-
bless you
The Engineer
Good Answers: 129
11/10/2008 1:41 PM
No, I can't. If you want this done, you're gonna have to do it.
11/10/2008 11:48 AM
Every creator of an unproven concept must stand realistic challenges/inquires into provable results.
The energy in...energy out is a legitimate question.
Instead of answering you hide behind the "I AM A VICTIM" statement.
Platitudes of "poor little me" do not generate any confidence in the validity of your conclusions.
Having built my first Tesla coil over 70 years ago, I can see your direction but not your conclusions.
MR. GUY.
If you are looking for a positive answer..it's YUP......
11/10/2008 1:11 PM
Here's the problem, you're making sensationalist claims that we've all heard before. If you want to be taken seriously the apparatus should have yielded a net gain of energy more out than in. This would be required before anyone would take you seriously enough to invest time and money to replicate your experiment. Your religious rants also do nothing to further your cause. In this forum you are addressing engineers, therefore try to limit your discussion to facts and figures and leave the religious statements out. Otherwise you'll be viewed as an attention-seeking zealot who cries wolf every time he's feeling lonely. You're also adding to the difficulty of presenting a viable method of acheiving cold fusion by making false claims and dashing the hopes of those who are patiently searching for it's secret. In short put up or shut up.
I would rather be ashes than dust...
11/10/2008 1:18 PM
I sure tried to read these posts, but you know, there was this movie, Chain Reaction, that was much more entertaining!
11/10/2008 2:06 PM
There are so many good inventions that are just ignored because they fly in the face of conventional science. It's to bad that you can't find anyone that will listen to your ideas. I can understand your troubles. I myself am a backyard inventor but lack the schooling and technical jargon for anyone to take my ideas seriously.
It seems that it has always been so. They laughed at the Wright Brothers and their flying machine, now we fly every day. Galileo was but under house arrest because he said the earth wasn't the center of the universe. And now we have flown to the moon. Even Tesla who has given use the ability to transmit power all over the globe was ridiculed, and died bankrupt. The best I can offer is keep at it. Science does not seem to like change very well and sometimes it needs a good kick in the pants.
I have no idea if your ideas are good or bad but I can see that you are passionate about them and thats what it seems is needed to carry our ideas beyond ourselves, that and they need to work. There are some very smart people on CR4 and it is a good place to exchange ideas. I have learn much from the discussions on CR4. In fact I was reading the other day about another idea that has seemed to have died from lack of interest and that is the "Resonant Nuclear Battery" invented by Paul Brown. Which uses radioactivity as a battery power source. After the inventor died is seems to have died as well. His invention would make use of nuclear waste, which we now just bury in the ground.
I hope you have better luck then he did because I don't think anyone is following his research.
Good luck
PS: And yes I got a little windy, I can get a little passionate myself. WE NEED MORE INVENTORS IN THIS WORLD. And yes our ideas can be pretty off the wall but that doesn't make us crack pots, just different thinkers.
Register to Reply 25 comments
Anonymous Poster (1); Bayes (3); Brave Sir Robin (1); Bricktop (1); DVader1000 (2); fishpipes (1); Milo (5); Mr. Guy (1); nick name (1); noblefuse (6); rakesh_semwal (1); The_curious_one (1); VMI1998 (1)
