Previous in Forum: Test for Lead in Water?   Next in Forum: Significance on kinamatic viscosity and dynamic viscosity.
Vapor Liquid Disengagement Area in Boiler
11/13/2008 11:53 AM
How one can calculate the disengagement area above the water level for steam in steam generator (Boiler)?
Re: Vapor Liquid Disengagement Area in Boiler
11/14/2008 6:54 PM
Errr...I don't think it can be calculated!
It can be measured though!
The minimum volume for disengagement is set at a point in which liquid begins to carry-over. Since steam is free of solids it has a very low conductivity and other attributes that influence quality. You can find the min. volume for disengagement by raising the steam drum level and monitoring the steam outlet with a sodium analyzer or similar instrument. You will see a jump in reading when liquid is carried over.
Steam quality is set based on boiler type. All boilers should meet ASME guidelines to ensure safe operation.
I hope this helps!
-David
