Hi all
I am doing EEE second year and having trouble with the question below. The
question has been repeated on every past exam i looked at..I asked the
teacher and he refused to answer it because apparently he puts this
question to separate boys from men!?!
A 240 volt, 2 hp, 1200 rpm dc shunt motor
drives a mechanical load which has a torque speed characteristic which is
proportional. The armature resistance of the motor is 0.75 ohms. With the field
current set to 1.0 amp, the motor draws a line current of 7.0 amps and rotates
at 1200 rpm. Assume a linear relationship between Ea and If and
neglect armature reaction. Friction and windage losses are to be assumed
constant and equal to 150 watts.
If the field current is now reduced to 0.7
amps by way of a series field resistance, calculate:
(a)
The new operating speed of the
motor
(b)
The new line current
(c)
The mechanical power delivered
to the load
(d)The efficiency of the machine
please give some ideas on how to solve it
thanks
swin
