Previous in Forum: How to calculate effective thermal resistivity??????   Next in Forum: Reverse power trip, under certain conditions
Short circuiting/earthing
11/16/2008 11:48 PM
Recently we had faced a problem of short circuiting in the main distribution board resulting in current shock.Luckily no body touched the board .It has been infd. by an electrician that the problem is due to giving way of one of the connections at the trafo outlet terminal ie incoming to the distribution board and one of the earthing points got cut which need to be renewed.Can anybody explain the reason and what precautionary steps to be taken to avoid accidents as normally in the multistoreyed complexes everybody depends on what the electrician says.
Engineering Fields - Power Engineering - Projects Engineer
Re: Short circuiting/earthing
11/17/2008 9:19 AM
U will need to elaborate more ,what do you mean by giving way of one of the connections, at the traffo outlet terminal. and one of the earthing terminal got cut ? which point ,is it after the short circuit or before.
The distribution board has an incommer and several outlets and ofcourse the earthing connections .
If the incommer has got loose and come out and touched the DB housing and there was no earthing on the board than that is a dangerous situation,definetly someone is not doing maintenance of your electricals
A wise person will understand more from a Foolish question than what a Fool will understand from a Wise Answer
Good Answers: 19
11/23/2008 3:03 AM
By your name i Could guess you are from south India.
kindly indicate you location.
Please elaborate your postings.
If you are in multi storey buildings there will be centralised transformer in the premises and it should be maintained by C certificate qualified Supervisor.
If the transformer is not located in your prmises you will get the LT supply from the utility supplier.
I do not think any shortcircuit, if so the incoming fuse would have blown.
May be there is a wire cut on the incoming supply or earthing connection would have given away.
More light can be thrown on this issue if proper/elaborate input is given
Ramesh,Freelance Electrical/automation Consultant
Register to Reply 2 comments
