Previous in Forum: Short circuiting/earthing   Next in Forum: protection failure....
Reverse power trip, under certain conditions
11/17/2008 12:12 AM
So Thanks before hand, Alright so here is the problem. I am running 3 generator on an oil rig, Gen 1 and gen 2 are on all time, gen 3 is only used when needed. Today i was told that gen 3 was tripping, there was 2 alarms on the woodward egcp-2 screen,
alarm 1 : Gen low frequency, alarm 2 : Reverse power alarm.
Now i know the basis of reverse power, but i was at this rig today for 5 hours, gen 3 ran the whole time sync'd with gen 1 and 2. It was load sharing fine, and did not trip during normal drilling. I have been told that when they Ran the drawworks down from midsection to the drill floor gen 3 tripped, ill be getting more info once im at the rig, and rig specialists know where to start looking? And any additional info you need to know let me know thanks
Re: Reverse power trip, under certain conditions
11/17/2008 1:48 AM
Low frequency and reverse power are synonymous in the sense whenever the speed of the engine drops reverse power conditions will develop and the other generators which are synced will push power back into the slower engine.
Now, when the drawworks are ran down does the load on gen increase or decrease?
cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
India - Member - New Member
11/17/2008 10:05 PM
Once the DG trips in Revers power, GCP Relay will sense as Low frequency.
You can check the revers power settings in EGCPs to start with and followed by DG-3 Fuel system. Since the fault does not occur during normal drilling, if must have to do with Fuel or settings.
Nothing is impossible, Impossible is nothing
07/03/2009 3:45 AM
Dear sir I Am Sebastian from Bangalore. Now I Am Working For BEL Chennai. Sync. Work Of 2X500 KVA & 1X125 KVA DG Set With Woodward Relay For More Information Pls. Call Me +91-9900-453-791 OR htpp://www.s4sindia.hpage.com E-Mail: sebastian.solution4system@aol.in
Anonymous Poster (1); chaterpilar (1); hara143 (1)
