Previous in Forum: about load calculations   Next in Forum: synchros
8 comments
Fire Alarm System
11/17/2008 2:36 AM
Please tell me how many factor involve to calculate no. of smoke/heat detector for a specific vanue or also provide me detail for claculation i will be very thankfull to you.
Re: Fire Alarm System
11/17/2008 6:59 AM
PEES
Go through NFPA 72.
For a start please note that it is assumed that the detectors are to be provided for a building. Principally the following factors govern the spacing between the detectors:
- Height of the roof/ cavity (in case of false floor and false ceiling)
- No of air changes inside the area
Now a days multi criteria detectors are available . These detectors can be tuned to act as ionisation type, photoelectric type of heat type of detectors.
Remember that it is recommended to have an equal no. of ionisation and photoelectric detectors in a given area. Heat detectors are normally used where presence of gas during normal operation will cause malfunctioning of the detectors, eg in battery room.
Then their are other types of detectors suitable for various locations and applications.
Hope that gives you a goahead for further study.
Atlas Shrugged - JGD
11/17/2008 11:07 AM
British Standard 5839.
11/17/2008 11:51 PM
hi dear
i am fire fighting and plumbing engineer in one of the india's biggest shopping mall ( under constrution ) .. brother right now i am little bit busy after lunch i will mail u all the required material and also the design and drawing of the mall. what so ever guidence u want, if i have the same i will provide u
bye
Ravinder K. Bawa
Location: Lincoln City, Oregon, Central Oregon Coast, USA
11/18/2008 12:35 AM
So,...PEES,...where on the globe are you located?
..."life is too busy to let boredom drop anchor."
11/18/2008 1:33 AM
but usually around 9meters distance between the two detectors can i have ur email address, i will send to you a pdf copy of the requirements...
11/19/2008 2:29 AM
hi bro my email is:-bawa333us@yahoo.com
please send me pdf copy of the requirements.
11/27/2008 5:48 AM
Thanks for response please note email for PDF file
peesconsult@hotmail.com
11/18/2008 11:03 AM
Welcome aboard! The answer depends on which country the work is done in. You already have responses citing NFPA (American) and British standards, and an offer of help from India, I'm sure there are others. All will be similar, none are guaranteed to be identical, and it's the little details that you need to be aware of. Knowing where you are working is critical...
Register to Reply 8 comments
Anonymous Poster (1); bawa333us (1); Current Maarey (1); EnviroMan (1); junbone101 (1); PEES (1); PWSlack (1); twisted piston (1)
